Results 1 to 10 of 14
Thread: VIA Boot Times
    Jan 2007
    Columbus, OH
    VIA Boot Times
    I know there are several threads about Post and Boot times but there aren't any specific to the VIA Boards. I have the M10000 and my boot time is now 65 seconds with XP SP2. What are yours?
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    Via m10000k XP Pro SP2 nlited
    5 second opus delay
    5 seconds on bios
    44 seconds after i turn my key i have my frontend loaded
    59 seconds after i turn my key music starts playing
    short answer 59 seconds
    but the windows booting process only takes about 34
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Jan 2007
    Columbus, OH
    I'm thinking about stripping down my windows install to see if it helps increase my time. I just did some tweaks and it is still taking 65 seconds exactly to put from switch to windows
    Jan 2007
    Columbus, OH
    Okay, so I upgraded my hard drive today and nlited my own copy of Windows XP SP2. My boot time is now just under 21 seconds! What a Difference!
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mdlesk View Post
    When I read the first 2 posts I was like "whoa... there is something seriously wrong here". 1minute for boot time is rediculous. That means something is not setup right.
    Harddrive will do the trick indeed. Also disable whatever you don't need in the BIOS. Speeds it up a bit too. And of course use wuick post after the initial startup.
    I get music in about 20 seconds as well with a full copy of XP Pro.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Columbus, OH
    Yeah, it was really bad! I was hoping to get boot in under 20 seconds, but i think it's going to be a little difficult.
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hi mdlesk,
    on my last rebuild, I documented the attached to try and get down to the elusive sub 20 sec boot time.
    Squeezing the juice out of an EPIA MII
    My findings however got me a Bootvis boot time of 16 secs, but then you need to add the bios boot, and any delays for your power up controller. The upshot is that from turning the key to getting music playing for me was around 50 secs, even with a documented 16 sec boot !
    I am sure other things can be done to assist. I have also started to build my PC's using Bullet XP which appears to be (for me) the most stable I have found, while still offering wireless support. It gets your install down to around 17 running processes, so the little epia appears to fly !
    Hope this helps.
    regards
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Newbie Machinist's Avatar
    Dec 2006
    Thanks for the documentary! I never knew Bootvis could be used to indicate boot times prior to operating system boot up. Have you considered disabling application layer gateway service, automatic updates, computer browser, error reporting, secondary logon, print spooler, security center, system restore from services.msc?
    Dec 2003
    West Midlands
    Quote Originally Posted by Machinist View Post
    Hi Machinist,
    Bootvis doesn't show BIOS boot times ! This is one of the difficulties when quoting boot times. My boot time is close to 50 secs when you take into account
    Turning the key to power up M2-ATX 5 secs
    BIOS BOOT 10 secs
    Windows boot prior to Bootvis being kicked off 10 secs
    RR boot to usable
    All in all from turning the key to rr operational is around 50 secs, but Bootvis shows a 16-17 sec boot !
    I am not that good around knowling what services can be removed, which is why I have started to use Bullet XP. This ends up with only 19 processes after boot, including RR and winamp, and saves me from further investigation !
    A good tip though for others to look at.
    cheers
    KPJUK
    FLAC mauri's Avatar
    Jan 2004
    For one very fast System,with EPIA MB,I use "TinyXP Beast Edition v5" ,one ultra lite version of XP SP2.
    Little use of CPU and RAM....best solution for CarPC system.
    Google search.... ;-)
    Mauri
  1. Boot times
    By 84RegalRider in forum Linux
    Last Post: 07-23-2007, 02:58 PM
  2. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 06:03 PM
  3. boot times with XP
    By Alives in forum General Hardware Discussion
    Last Post: 11-15-2001, 12:42 PM
  4. boot times
    By pinkysqueaks in forum General MP3Car Discussion
    Last Post: 08-31-2001, 06:30 PM
  5. boot times for mp3 players
    By alany in forum General Hardware Discussion
    Last Post: 12-16-1999, 12:09 AM
