Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
Thread: Reducing Return From Hibernation Time......
  1. #21
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    1. POST = Power On Self Test. Yep, it's the bios start up time, from when the button is pushed to when it hands off to the OS. It has everything to do with the motherboard and bios, and nothing to do with whatever OS you have on there.
    2. I must be old cuz I've had computers with 4MB of SIMM memory. Yes, 256MB is more than enough for windows. Most carpc's don't need much memory anyways because you're not dealing with large programs or files.
    3. No. I mentioned the M2 in response to jmciver talking about the M2. You can substitute any power supply in what I said. The power supply provides power in the form of the various voltages on the rails, the amps when the demand calls for it, and as clean (low ripple) as possible. A motherboard doesn't care where the power comes from or how many blue led fans it has or the maker of the PSU as long as the power is there when it wants it.
  2. #22
    May 2006
    Quote Originally Posted by psyrex View Post
    Wow, thanks for the very thorough answer. I think my question was is there a delay in any PSUs over other PSUs, but I suppose that is a dumb question. Thanks.
  3. #23
    Nov 2005
    Yup. After I thought about my post on the M2-ATX I realzed the error of my ways. Thanks for clearing that up.
  4. #24
    May 2006
    Calgary, Alberta
    subscribed
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  5. #25
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    This is a great thread, I was going to actually start one about this topic before I saw it. I will try BOOTVIZ to see what takes so long to bring up my machine from hibernate. Chances are it's the 5200rpm WD drive that's not fit for a 512MB dump.
    I always wondered if Windows dumps everything including empty memory addresses, or if it only dumps whatever is used up at the time it's shutting down. Guess it dumps everything at once, including zeros.
    One of my biggest delays it the time from power to the PSU starting the machine. My 90W OPUS has a long delay which I will remedy with my own SD controller.
  6. #26
    May 2006
    How will an extra shut down controller help your boot up time? Doesn't the opus have a shut down controller? Thanks.
    -Ross
  7. #27
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Quote Originally Posted by LiquidKernel View Post
    Pretty sure windows only dumps used memory addresses.
  8. #28
    Jun 2005
    Oakland, CA
    LiquidKernel:
    well, bootvis won't help you much with that. A startup sequence includes your SDC delays, BIOS delays, and then resume/boot. bootvis can only help you after the BIOS for the boot part. However, with hibernation resume, the boot portion is simply a file dump into memory. It just takes the image it had created and slaps it onto your memory. There's no real bootup and nothing really to tweak other than decreasing the amount of RAM you have.
    For example, I have 512MB of RAM and have been thinking about decreasing that to 256MB to get to music faster. With a stopwatch, this is my startup time:
    1) Key turn to MB power on: 2 sec
    2) BIOS to OS handoff: 15 sec
    3) Resume from hibernate: 10 sec (<-- the time that bootvis reports)
    total: 27 sec
    If I decrease to 256MB, the only part that is affected is (3) resuming from hibernate. Cutting the memory in half approximately decreases that time in half, down to 5 seconds. My total startup time then would be 22 seconds.
    Nerd2: No, it dumps everything. If you use hibernation, look for the file c:\hiberfil.sys. That file is the same size as your memory. Everything that's in memory is placed in the file. If you have 512MB of memory, you'll have a 512MB hiberfil.sys file.
  9. #29
    Feb 2005
    Quote Originally Posted by gunsandrosses View Post
    -Ross
    Not an extra one, but a replacement for the OPUS. I will disable the onboard OPUS controller. It has a 8-10 second delay between key turn to MB power. The controller I'll write on an Atmel will have a shorter delay for the start up.
    The OPUS does have one, but while it works, it could be better. Too bad they never released the source for the MCU on their PSU.
  10. #30
    Feb 2005
    LiquidKernel:
    total: 27 sec
    That was my initial thought as well. Even though BOOTVIZ does have an option for hibernate, it shouldn't make a difference. Another think I'll check out is using a faster hard drive. My gf's laptop with the same amount of ram takes half the time to boot up, and it's not that fast of a laptop either.
  1. 512MB or 256MB (need to cut down hibernation load time)
    By jackdon in forum Operating System Optimization
    Last Post: 10-11-2006, 10:33 PM
  2. Resume time from hibernation with EPIA M/B's
    By toxsickcity in forum Software & Software Development
    Last Post: 09-22-2005, 12:32 AM
  3. Replies: 4
    Last Post: 06-03-2005, 01:59 AM
  4. return from hibernation screen change?
    By llajumpvid in forum Software & Software Development
    Last Post: 06-02-2005, 08:49 AM
  5. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 05:41 PM
