Results 1 to 10 of 10
Thread: Soap vs rest
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Soap vs rest
    Matt did something similar, but I just wanted to post a pros/cons list of my own and finalize the debate over the protocol/data transfer mechanism:
    SOAP
    Pros:
    - Supports Complex arguments and return types
    - Can generate code from WSDL (no parsing on client)
    - Supports Security and Encryption.
    Cons:
    - Heavier protocol when compared to REST
    REST
    Pros:
    - Lightweight for simple calls
    - Supports return results in XML
    Cons:
    - Client still has to do parsing (this will likely be abstracted via the OSDash Client library/assembly).
    I'm sure there are more pros/cons to each. Personally, I think the code generation and automatic parsing is the killer feature of SOAP. I'd like to hear what other people think on the debate. I'll keep this OP updated with additional pro's con's as comments appear...
    Former author of LinuxICE, nghost.
    Current author of nobdy.
    fka - Nextabyte_Matt ioi8's Avatar
    Apr 2006
    Cleveland
    If you can stick with simple data types, using a RESTful approach is the easiest. Although simple data types may not be possible for all all web calls.
    However, we may not need to decide. If using the C# (.NET) programming language, it automatically provides support for both. Look at my example below.
    Webservice Call
    Code:
    [WebMethod(Description = "Returns search results for custom searches")]
            public SearchLocations[] Search(double longitude, double latitude, string searchtext)
                GoogleConnector myConnect = new GoogleConnector();
                GPSLocation myGPS = new GPSLocation(longitude, latitude);
                return myConnect.Search(searchtext, myGPS);
    Soap Call
    Code:
    POST /DrivnOnline.asmx HTTP/1.1
    Host: localhost
    Content-Type: text/xml; charset=utf-8
    Content-Length: length
    SOAPAction: "http://nextabyte.com/webservices/Search"
    <?xml version="1.0" encoding="utf-8"?>
    <soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
      <soap:Body>
        <Search xmlns="http://nextabyte.com/webservices">
          <longitude>double</longitude>
          <latitude>double</latitude>
          <searchtext>string</searchtext>
        </Search>
      </soap:Body>
    </soap:Envelope>
    RESTful Call
    Code:
    POST /DrivnOnline.asmx/Search HTTP/1.1
    Host: localhost
    Content-Type: application/x-www-form-urlencoded
    www.somewebsite.com/servicename/Search?longitude=string&latitude=string&searchtext=string
    While RESTful is the easiest to do for simple functions with basic datatypes.... NOT ALL FUNCTIONS will allow for simple datatypes. For client-webservice calls, I think the best way to go is full SOAP compatibility. While harder to use, it offers so much more functionality.
    However, for web front-ends, RESTful is a must as using SOAP is much more complex using PHP and HTML. For calls made by web calls, REST should be used if possible.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    You should add proprietary verse open to the pro/con list
    I would definitely put my vote in for REST for the simplicity, lack of bloat and backwards compatibility. I would also be curious for an example of a properly designed web service that needed anything more then simple datatypes?
    FLAC SFiorito's Avatar
    May 2004
    Not sure if you mean SOAP or REST as being proprietary. But neither one is proprietary. SOAP least of all. The advantage of SOAP is that is has full, well defined, and supported standards in the WS-* stack. REST is just an architectural concept that is based on using HTTP and XML, both open standards.
    Using REST (HTTP/XML) ensures all sorts of technologies and devices can integrate with the services, as long as the client can do XML and HTTP. The full SOAP stack is not always supported everywhere. Also, SOAP tends to be far more verbose than simple XML serialization. Something to keep in mind since a lot of people may be using pay-as-you-go or limited mobile data plans.
    Also, you can absolutely use complex data types in REST. In fact (for either SOAP or REST), I would highly recommend using request/response objects to enclose the parameters to your service calls rather than passing a large list of parameters. This makes updating and versioning the services easier.
    So you could have a C# class for location such as:
    Code:
        [DataContract(
            Name="location",
            Namespace="http://osdash/models/2009/12")]
        public class Location
            [DataMember(Name = "latitude")]
            public double Latitude { get; set; }
            [DataMember(Name = "longitude")]
            public double Longitude { get; set; }
    An instance will serialize as such:
    Code:
    <location xmlns="http://osdash/models/2009/12">
       <latitude>0</latitude>
       <longitude>0</longitude>
    </location>
    For generating proxies, you could publish schemas to your objects. Most languages have tools to serialize from objects to XML and vice-versa.
    For versioning, let's say you publish a Location service with an update call that takes the Location object above. For some reason you later decide the Location object should also have speed and heading values. You don't need to change your service interface or code, just the Location definition. You could then make the new values optional so legacy clients can still use your service without causing breaking changes.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    When you say "complex data types" what do you mean, something like an array or maybe a streaming audio file or...?
    Is it possible for the standard to support both RESTful AND SOAP? Although it does seem that mainly REST is sufficient for now, who knows what future services may need? Is there a clever way to specify the type in a header or with a software swith or the like? That might allow for future service types to be added while keeping legacy support...
    Want to:
    Apr 2006
    Cleveland
    Quote Originally Posted by Bugbyte View Post
    Simple Data Types
    • integer
    • string
    • boolean
    Complex Data Types
    • Objects
    • Arrays
    • Structs
    Streaming audio is somewhat out of the scope at the moment. I dont think anyone here has the knowledge of setting up their own format/protocol. We would need to use 3rd party tools to accomplish this.
    Apr 2006
    Cleveland
    Look at my post above. I showed how the same function can accept both SOAP and RESTful function calls. Unless a complex datatype is requested in the function, a function can support both types.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    REST has full support for arrays and structs and theres never a case where a generic object should be used in a web service. Supporting both where possible is certainly a good idea (using the method above) but I think the preferred choice was REST, especially on low bandwidth mobile connections.
    Apr 2006
    Cleveland
    Quote Originally Posted by justchat_1 View Post
    Whats the call format for using a complex data type with REST? My C# example doesnt show a REST example whenever I compile with complex data types.
    May 2004
    For WCF REST, using the Location object above all you do is define a service contract such as this:
    Code:
        [ServiceContract(Name="LocationService")]
        public interface ILocationService
            [OperationContract]
            [WebGet(
                BodyStyle=WebMessageBodyStyle.Bare,
                RequestFormat = WebMessageFormat.Xml,
                ResponseFormat = WebMessageFormat.Xml,
                UriTemplate = "{user}")]
            Location GetLocation(string user);
    The HTTP traffic would like like this:
    Code:
    GET http://server/location/joe HTTP/1.1
    Code:
    HTTP/1.1 200 OK
    Content-Length: 153
    Content-Type: application/xml; charset=utf-8
    <location xmlns="urn:osdash/models/2009/12">
    </location>
    VoomPC 2
  1. Create a Fold down arm rest in a bench seat?
    By rebel2002 in forum Fabrication
    Last Post: 02-24-2009, 05:37 AM
  2. True DDIN for the rest of us?!
    By riscy in forum LCD/Display
    Last Post: 01-30-2008, 12:46 PM
  3. Mr. Clean Auto Dry soap Alternatives?
    By bosstone74 in forum Off Topic
    Last Post: 08-28-2005, 10:53 PM
  4. Replies: 2
    Last Post: 04-04-2005, 04:01 AM
  5. XENARC Head rest mount --->
    By Jeremyvnc in forum LCD/Display
    Last Post: 09-02-2004, 08:16 AM
