You guys may be missing the point. Sure unique services will be a great value-added feature, but I think the strength of doing this is to consolidate all the APIs on the web into a single API rolled into one. See below for what I mean.
By doing this, everyone has access to the same APIs, no matter what front-end. We can format the data and standardize it. Also, the server can do most of the work instead of an already over-worked carputer.
If you have ever worked with the google API as I have, you will know that much work is required to get at the data that is needed. I say let the server retrieve the data, strip away what isnt needed, and then send a condensed file over the 3G connection. This will speed up data transfers and also be much better for those people who have bandwidth restrictions.
Here is what I mean in picture format.
http://www.mp3car.com/vbulletin/imag...c394993220.png
BTW... me and kev000 have been working together to develop this for our own project. Seems he wants to go public with it and make this open-source. I do have some code right now that does the following things:
- Syncs a trip database between client and online DB (100% complete)
- Syncs a POI database between client and online DB (100% complete)
- Searches google maps based on current GPS location (90% complete)
- Searches google maps by another address and/or zip code (90% complete)
The code for the google search may not be pretty, but it works quite well. The syncing between client and online DB allows for an unlimited amount of clients to connect and edit the data. This means thats you could create a trip online, hop in your car, and it would download when your car syncs online.
