Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
Thread: High performance RR like frontend - Alpha testversion
  1. #11
    Mar 2006
    @cdrskull:
    RR transfers the whole filelist, as sama speculated...
    I transfer only the files who are "visible" to the user, but that does not mean i send something else then a string...its the same string as rr transfers.
    Play and goto command exist like in rr.
    As i wrote in the title its "rr like"...
    You have great skins, maybe you give it a try and adapt one (or only the main menu for testing)? Its easy...
  2. #12
    FLAC sama's Avatar
    Feb 2006
    London, UK
    hehe, I'm not trying anything I'm just interested in how you solved that part. As you know, I decided not to use fscommand and went for a TCP/IP approach, which has implications for Flash 8's primitive tcp handling. Flex which I'm currently working on upgrading the code to, doesn't have these issues.
    I used pagination to solve it, which is more or less what you're doing. Only showing part of the data as required.
  3. #13
    Dec 2006
    i cant download this the links dont seem to work?
  4. #14
    Mar 2006
    @sama: i thought fscommand is only working, when you have control over the flash container - so you must use something other, or i am wrong with this?
    @astrapc: its posted directly in the forum, there is no link
  5. #15
    FLAC sama's Avatar
    Feb 2006
    London, UK
    you can use exec on fscommand to launch a command, and using that, pass params to an external app if you want using a custom command line. too hacky for my liking.
  6. #16
    Jan 2005
    Sweden
    Quote Originally Posted by ReflexNPG View Post
    @HaPe: did you already tested, if it runs on your machine?
    Please post some test results (CPU load, Hibernation ok, etc)...
    I have a Celeron 500 MHz and i have 10% load - Hibernation (also during playback) runs perfect -> continues to play and normal screen update...
    No havn't tried it yet. Didn't have .net V2.0 installed.
  7. #17
    Mar 2006
    Update in the 1st post: internal gps and external application support....
  8. #18
    MySQL Error
    Oct 2004
    just excepts for me...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #19
    Constant Bitrate Road_Dog's Avatar
    Nov 2006
    USA, Oregon
    It halts with "encounter an error and needs to close" error for me as well.
    Road_Dog
  10. #20
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    you dare take on the beast?!? Just kidding, if your going to do it stick to it. Guino, it says something if most are trying to top your frontend, and not one they paid alot for. Good job!
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  1. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  2. Frontend with decent performance?
    By Mears in forum Software & Software Development
    Last Post: 12-23-2006, 12:07 PM
  3. Replies: 4
    Last Post: 10-19-2006, 09:45 PM
  4. RR performance and video card
    By jac1502 in forum Road Runner
    Last Post: 05-05-2006, 08:08 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
