@mitchjs & road dog:
i think you are missing some components...i've tried it on 4 pc's and it starts everywhere.
@proph: i am glad that rr exists and i've used it 4 a year or something. but rr is coded "old style" with many string compares, loops and timers.
The handling of non flash skins is also a big par of it. I've started to rewrite the main code of rr, but there is too much i dont need...
My frontend just shows, that its possible 2 do it with less cpu power.
Ive downloaded and installed this frontend. I changed the audiobroser.skin file path to the my music folder but still cannot see the library in the program. Also do you have "nicer" looking skins? Thanks great frontend
@carfreak01: did you tried another path? can you see the directories? what kind of filetypes do you have?
About the skin: you are invited to make one, or you can port if from rr - but it must be a flash skin...
anyone else have this working?
I have it working on my desktop computer.
Found one little bug with national characters in the audio browser. It doesn't display the swedish character å. the other two we have (ä,ö) displays right.
major update - alpha 06 - see first post
@HaPe:
thanks 4 the info - i think this character is not embedded in the flash skin, so its easy 2 fix.
@proph:
please install the necessary components (without flash 9 it will not run)
I need a debug log... My "FU" skin in RR works fine (uses flash). I don't know what it is...
@proph:
sorry, but you have to adapt your skin 4 my frontend...
alpha 06 just crashes for me. Havn't got any problems with the earlier versions. Does it look for something in the 3 folders in carmen.ini ?
