Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
Thread: High performance RR like frontend - Alpha testversion
  1. #31
    Mar 2006
    @HaPe:
    sorry, i've had a reference included 4 AudioGenie, which will be used in a future version.
    Please try the fix in the first post - there is now also a log file in the application directory.
  2. #32
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    @Reflex:
    20070624 @ 17:06:53 ************ Carmen starting up
    20070624 @ 17:06:53 Error creating activewinamp object - Exception:Retrieving the COM class factory for component with CLSID {1C7F39AF-65C0-4C14-A392-6B4714705DC2} failed due to the following error: 80040154. - System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {1C7F39AF-65C0-4C14-A392-6B4714705DC2} failed due to the following error: 80040154.
    at Carmen.AudioPlayer..cctor()
    20070624 @ 17:06:54 Problem opening com port - Exception:The port 'COM2' does not exist. - System.IO.IOException: The port 'COM2' does not exist.
    at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
    at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
    at System.IO.Ports.SerialPort.Open()
    at Carmen.GpsReader.CheckComPort(Object o)
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  3. #33
    Mar 2006
    Quote Originally Posted by proph View Post
    install activewinamp
    setup the right comport in menu.skin - this error does not prevent the program from starting...
  4. #34
    Mar 2006
    major update: video browser, cover art etc...please see 1st post
  5. #35
    Sep 2005
    Carmen has stopped working
    Does this run in Vista? I've installed all the components, actually active winamp got stuck with trying to register the dll (I had to register it manually)
    and I have set the paths properly.
    All I get is "Carmen Stopped Working"
    Here is the windows description.. not sure if it helps..
    Description:
    Stopped working
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Carmen.exe
    Application Version: 1.0.0.0
    Application Timestamp: 467c5f57
    Fault Module Name: KERNEL32.dll
    Fault Module Version: 6.0.6000.16386
    Fault Module Timestamp: 4549bd80
    Exception Code: e0434f4d
    Exception Offset: 0001b09e
    OS Version: 6.0.6000.2.0.0.256.1
    Locale ID: 1033
  6. #36
    Mar 2006
    @Efess: sorry, i dont use Vista...
    maybe there is something in the logfile( in the application directory).
  7. #37
    Sep 2005
    Doesn't look like the log file wasn't created yet
    *was
  8. #38
    Mar 2006
    well that means its probably a problem with .net, cause creation of the log file is the first command in the program...
  9. #39
    Sep 2005
    Weird. I develop in .net 2.0 on this computer, never had a problem Let me know if you find anything. I will as well.
  10. #40
    Mar 2006
    if you are interested, i can send you the source and you can try to compile it...
  1. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 07:10 PM
  2. Frontend with decent performance?
    By Mears in forum Software & Software Development
    Last Post: 12-23-2006, 11:07 AM
  3. Replies: 4
    Last Post: 10-19-2006, 08:45 PM
  4. RR performance and video card
    By jac1502 in forum Road Runner
    Last Post: 05-05-2006, 07:08 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
