Results 1 to 10 of 11
Thread: DestiPlus v5.61 Installation Instructions
    Jun 2007
    Melbourne
    Since the forum to get the app, and the developer, are both german I thought id share the steps I used to get it working
    Everything except for the maps you get from: http://www.mp3car.com/vbulletin/newt...ewthread&f=113
    You do have to sign up, and it is in german. Google translation tool can help you work out which fields you have to fill in for the registration. Once you have a registered and signed in you should be able to go to the above link.
    From the first page grab:
    DestiPLus v5.61 by jennico.exe
    Language5.0.zip
    Destinator PN.rar
    The maps you can get from your Destinator 6 CD.
    For the example I have installed everything in to c:\desti. Destiplus doesnt like spaces in the filename.. so...
    1) Create a directory in C: called Desti
    2) Extract Destinator PN.rar to C:\Desti
    3) Extract Languages5.0.zip to c:\Desti
    4) Delete the Berlin Map folder (unless you want it)
    5) Copy the map folder to c:\desti
    6) Install DestiPLus v5.6.1 to c:\desti. When the language screen appears I choose English as the language (click on the yellow dual arrow button) and chose USA as the country, then click on Ready
    At this stage you should get a couple of prompts regarding license agreements, once you click on these Desiplus will go through its configuration routine that takes about 1 min. The application will appear to open and close a few times. Just wait till it stops. You should get a "Welcome and have fun with DestiPLUS" splash screen that you can click on.
    Hopefully this will save someone some time
    Low Bitrate Supergong's Avatar
    Jan 2006
    Germany
    For those who dont know what Destiplus is (i was asked to explain cause iam german):
    Destiplus is a skinbedder skin for Destinator 6 which is provided by Centrafuse!
    It uses Skinbedder (although Jennico renamed it) and some AutoIT scripts to accomplish things easier (onscreen Keyboard, config of Comports, Gui layout etc)
    The new SDK provided by Centrafuse( from 1.12 on) does have a OSK but still needs configs for Buttons, Comports etc......
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Why not just use D6, that doesn't need a GPS frontend like DestiPlus, Freedrive, or Mapmonkey.
    All you need to do is skin it to suit your main frontend Skin
    Search for Destinator 6 Howto
    Aug 2007
    Quote Originally Posted by ShawJohn View Post
    Hi,
    maybe i am a bit thick, but i searched for what you specify on the forum, but can't find anything?
    Jun 2007
    Melbourne
    Quote Originally Posted by Bass850 View Post
    Hi,
    You have to sign up and be logged in to the site to find the file download links
    _
    Mar 2004
    Little Elm, Texas
    You might want to check the link in your first post....it's not linking to what you're wanting it to link to I guess.
    Jan Bennett
    Jun 2007
    Melbourne
    Hrm.... bugger... it doesnt.... Need to wade through german again.. EEP
    Stay tuned
    Sep 2007
    bump
    Sep 2007
    Feb 2007
    Thx
  1. DestiPLUS Frontend SDK for Destinator PN/6
    By jennico in forum Other Cool Front Ends
    Last Post: 07-16-2007, 08:08 PM
  2. Digistar-X V2 Instructions
    By BLOWNZO6_pc in forum General Hardware Discussion
    Last Post: 09-15-2005, 07:35 PM
  3. Replies: 0
    Last Post: 04-14-2005, 08:47 AM
  4. Replies: 9
    Last Post: 03-31-2005, 03:40 AM
