ya you can remove the buttons if you edit the Skins ini file. Rename them or remove them![]()
Yes, could you explain a bit more please? I tried removing buttons from the .ini file but I end up with a FE that doesnt load anymore.
Firstly let me say "Wonderful piece of software"...I just wish i could read German, i am sure there is alot of great info on the forum
i have tried to read the whole thread and found out a few things
I installed CaveLive2Alpha and a few odd things:
With a MP3 playing and i go back to menu (all 3 menus) the different set of home icons have a different visulization. 2 things i seek, Either have all three the same or at least change the main menu -- all the OOO
Also is there a way to open one whole album from one click
--Artist
-----Album
--------MP3s
--Artist
etc...
"Geeks dont need girlfriends we can ping ourselves"
Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
What a great front end.
Just wondering if tere is a way or if tere are any plans to make any specific gps embed into the skin itself....like the winamp visualisation does.....i think that would make it spot on!!!
Also, has anyone got it to start up and not mute the sound...as I cant understand how this can be changed! other than that...cracking front end!
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
Hi, i recently tried this front end in my car and it is great. Good Work
However i think it would be better if when you play a video clip and then decide you have finished with the video and want to go back to music, it would "unload" the video rather than just keep it paused.
Maybe a stop button could be implented aswell as pause because i find my cave live takes longer to load up now that i have run a video in it and i get this video box appear while it is loading and sometimes it crashes at this stage.
Also how can i access the internet or internet explorer in cave live?
I had a good look around in it today and couldnt find anything?
Did i miss it?
Thanks again
One More thing, i use a powermate with cave live and even with my sensitivity set on full it still takes an age to increase the volume (or decrese) significantly.
Is it not possible for it to change on a 5% basis rather than 1%?
Update from my last post (see below)
And could someone explain the side buttons on the audio menu?
The English setup link seems to be dead. Is there an updated link?
