I am having a few problems with the beta that I wasn't with the alpha version. I posted them in the English section of the forums for you.
Web programming is what I do. PHP, MySql, CSS, Html, XAML, JS, Perl, and a few other.
As for plugins, you need to get the common navigation software's integrated. Then satellite radio. Then a skin maker. Also I would make a robust and simple to use plugin creation system so you can be sure to get alot of 3rd party plugins developed.
Your system is very nice and I see alot of potential in it. More than most too. Even if you goal is to commercialize it one day, I hope you continue.
1999 Black Camaro Z28
Lilliput 701-Athlon 64 2800-512ddr-40gb-Earthmate GPS-iNav-RoadRunner-Wifi
Installed.. Finally
After some tests we made a Edition without WinAmpVis because of performance of V2.0.
We have also new functions:
- Audiofading /Crossover if in setup activated and times set.
- ext. application are better to configure in setup in a list with edit,deleting,set position of app , maximize or normal windowed start.....
- userbuttons for ext. apps are possible (see example in menu extApps and in blueage.ini)
also some bugfixes..... cAVe Portal
regards, bluescreen25
Thanks bluescreen. How do you get the original skin to work in the new version, I can't seem to get it to work.
Also, a request. Any chance you could get XM/Sirrus Satellite radio and an HD radio tuner supported?
Great FE!
I really like the graphic styles.
Few issues though:
*Nevermind, figured out what I was doing wrong!*
1. Won't save my music folder location. I've defined it in the ini and through setup. I have to navigate to it everytime I open the program. I should be able to define a folder and have it load up every song in there at once if I wish. Not everyone uses playlists, I load my entire library and just let the program "shuffle" though the songs. Playlists are just a PITA to me.......
2. HD radio support
This is a MUST for NA use. Almost everyone is using Mitchjs's app (http://www.rush2112.net/index.php?in...on_view&idev=5) or soon will be, for Radio. *kind of sorted. I can embed it with the ext app button, but a propper dll or at least radio button would be best.*
*sorted, thanks to SuperJ and Bluesscreen great writeup. Don't know what I was thinking*
3. Most annoying of all, cave mutes the main volume and turns it down to "0" on the system volume everytime it starts! The mute button in cave will un-mute the main volume, but you must open the mixer or system tray app to turn it back up again! This can't be the way it's supposed to work!
4. Visualizations.
Well, what can I say. The bar meter is nice and all, but I like to be able to scroll though the visualizations. I would seriously consider adding them back in if the speed issues could be worked out.
5. Shuffle.
There doesn't seem to be a "shuffle" option for songs. There is a "repeat" option but no shuffle. This is a near essential for those with large collections and want to listen to a nice variety of their music. Is there no shuffle option or am I just missing it?
*nevermind, it wasn't doing it, now it is.*
6. Is there an option to highlight or display the song being played in the audio list? Having to scroll through the while list to see the song playing (indicated by the small play icon) is a pita. I know the song is displayed at the tp of the page, but sometimes I may want to paly a song by the same artist that may be next to the song being played.
*sorted. IG4 embeds just fine when defined properly*
7.IGuidance 4 (Most popular NA GPS program) works just fine with cave, as long as you get the program file name correct in the setup utility.
8. English support
Forums, program, apps! I know it's not your native tongue and your english is way better than my german, but more support in english would really help your FE "take off". I was a little lost in the config program until I dropped in the english exe into the root folder. Worked great, but some things are still a little unclear. Error messages in german are kind of confusing too.
In all fairness, I've only been messing with the program for about an hour or two, so many of the issues may be in my settings.
All in all, a great FE in the making. Very well turned out for a "young" program.
Congratulations on a very slick interface!
Leonardo Da Vinci
cAVe Live
X1000000 HD radio and Satellite radio support are the only two things keeping me from using this full time.2. HD radio support is a MUST for NA use. Almost everyone is using Mitchjs's app (http://www.rush2112.net/index.php?in...on_view&idev=5) or soon will be, for Radio. I can embed it with the ext app button, so it shouldn't be too hard to add.
That got it! Thanks, I must've read right past that post somehow.....
I just defined "apps" as the hd radio and it embeds Mitch's pcr prog just fine. It'll work for now. I may look into seeing if I can have the radio button pull up the hd radio instead.
I've also got IG4 working fine as the gps app also......
Leonardo Da Vinci
What does FUhr next to the clock indicate?
I think uhr is german for "clock". What's the "F"?
Leonardo Da Vinci
Great White, what hardware are you using for HD radio reception? That's on my list of things to buy this week. Do you know of any similar satellite radio apps that can be embedded into CaveLive?
