Your adjust for the Mixer is not correct.
Your must open the Windowsmixer and change the Masterslider, in the Form from cAVe-Mixer-Setup you see the Mixer-Id of the Masterslider under 'Mixer ID Test'. This ID you must insert in the Combobox(MixerID). Also you must change the Wave,Line-In,Mic-In and CD-In Slider.
Wal
Commell LV-673, Pentium M 2GHz 533FB, 1024MB RAM, 40GB 2,5'' Festplatte, Pioneer DVR-K05 DVD, Soundblaster Live 24-Bit USB, Hami 8'' TFT, Velleman K8055 I/O Card, Selfmade Blaupunkt TwinTuner Radio
GPS: "MapFactor PC-Navigator 7"
Frontend: "cAVe_Live"
Can you go into the spectrum settings a little. i've been playing with them but i'd like to know what i'm doing....
...you know, that guy...
Hate to ask twice, but i can't get the screen size to change? anyone?
that doesn't work for me i tried it many times to adjst the volume.
@tn6478
Congratulations,you are first with that the those do not function.
Give me a Picture of your Mixersettings.
Wal
its not that it dont work. it get adjusted but my music keep on muting everytime i turn the program on. the master volume get mute. it also mute everytime i switch video. I am using the jetway 1.5ghz mb. I only see this happen on this motherboard and not my test system. Also i really dont like the way the volume try gain up everytime u switch track it get annoying.
mine was a easy fix. first started with labeling the mixer id's (1-7) then for the first two WAV and MASTER i set them to WAV and boom....everything works, may not be ideal but video, audio works like a champ. screen size let me see if i remember what i did, i'll get back.
cant not run your new version from 5-8-07...get a error when start the program..the first version i try works ok..
volke
i get this error...zugriffsverletzung bei adresse 004a8136 in modul cavesetup.exe lesen von adresse 000000b4
