Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Flash Frontend
  1. #31
    Vendor - Qube colin's Avatar
    Dec 2006
    There has never been a release to download. Unless you know both Delphi and Flash (AS 2.0) then it's useless right now. Plus it only works with the hardware I have available -- GPS, Visteon Radio, Custom USB controller board.
  2. #32
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I did a flash frontend ages ago.. FreeIce its knocking about on here somewhere.. had a vb backend.
  3. #33
    Apr 2009
    if your developing in AIR then surely your already beating the other front ends by the fact you can run it on anything
  4. #34
    Dec 2006
    Im developing in Adobe Flash straight up. CS3 I believe, but using the original actionscipt because I like my event handlers to be placed on the objects rather than in a main frame with listeners.
    Havent posted much here since nobodys really interested.
  5. #35
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Check out my flash projects for RR in my sig....I'm working on widget type components for RR.
    It would be awesome if more actionscript coders jumped on board... I've got so many ideas , but so little time..
  6. #36
    Apr 2009
    you guys have inspired me to build a flash/flex/AIR frontend. but first off i'ld like to know what features you'ld like on it. just reply to this thread
  7. #37
    May 2006
    Calgary, Alberta
    Don't know if anyone mentioned it yet but there is a complete front end called FreeICE that is all Flash.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  8. #38
    Dec 2006
    I started to like eLite a bit so I sort of copied a bit of the idea from that with the glossy borders and the tab buttons. Completely new interface (started):
  1. XUL Frontend....
    By SFiorito in forum Software & Software Development
    Last Post: 10-02-2009, 11:23 AM
  2. Replies: 33
    Last Post: 03-28-2008, 02:18 PM
  3. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  4. Replies: 0
    Last Post: 11-19-2005, 02:47 PM
  5. Destinator 3 Frontend v1.1
    By Ninja Monkey in forum Map Monkey
    Last Post: 10-25-2004, 10:40 PM
