Hi Gradecak,
Yes only that 2 buttons, ( in fact the music button only) works. I did not implemented all others since I have decided to change the interface as well the programing language.
Sorry for that, in case you interested to develop that version just let me know and I'll send you the sources.
Rob
Failure is not an option...
_________________________________________
The open source C# Front End -> OpenMobile
Hi Borte,
If you have read the first post than you have got the idea why I change the programming language ...
For the rest, yes I can send to you, but its completly new code, far away from the first one. I also used to google to get some ideas how to make thinks works for .Net. If you interest send me PM.
Rob
Hi again,
I have read the first post but I didnt understand if you had ended up on C# or .Net.
Is it so that you have changed like this: VB6->.Net-<C# and WPF? If so what was the reason for your change from .Net to C# with WPF? Isn't WPF a lot harder to run for a "older" computer?
Is your source for .Net or C#?
Cheers
Borte
Hi Borte,
I have changed to C# with WPF stright away from VB6. There was not VB.Net between
I was thinking about, but I found examples used C# and XAML so I stick on that.
Why I really changed? Cause I wanted to make the UI more animated 3D, as well more nice.
For that WPF more heavy for an older computer... I never tired, could be...
But as everything has some advantage (e.g nice UI), also has disadvantage...
Rob
WPF is a lot better choice than traditional WinForms, as it uses relative dimensions and such (not resolution dependant when done right). Also, I'd say WPF UI runs a lot smoother than WinForm UI when talking about complex visual effects.
Planning to switch to WPF myself too.
I Rob,
Where can i to download your completed frontend .
Thanks![]()
