Results 1 to 6 of 6
Thread: Another one...
    Nov 2007
    Another one...
    MODERATORS: As I'm new(ish) I guess this'll be moderated before being published. Let me know if any of the URLs aren't working. Thanks!
    Hello,
    Been building a Car PC on and off for the last few years, and had the same problem as many people do in that no front ends worked exactly as I wanted, so as usual I decided to write my own. Didn't expect it to take quite so long but...
    It's VB6 based, and has a fairly limited scope as my desire was for it to run responsively on my M9000 board, tie together my very disorganised mp3 collection and allow occasional satnav. Here's what it does:
    mp3 and wav courtesy of the Bass Engine
    Parametric EQ
    Basic Video player (MP Classic)
    Simple picture viewer
    Embedded navigation software (I use Sygic), but not really integrated
    Music database based on sqlite
    Basic notes/calendar/calculator (that now I've written I'm not sure I'll use!)
    Day and Night mode
    Here's the stuff it doesn't do!
    wma/flac/ogg etc
    no album art (hardly have any anyway)
    volume control
    dvd
    cd audio
    radio
    you can redefine the graphics, but it's not really skinnable as such
    any kind of internet data services
    OBD (but my car predates OBD by a long way)
    stuck in 800x600
    loads of other stuff
    ... this is because all my music is mp3 and I'm running the PC through my head unit.
    Anyway, I thought I'd make the software available just to see what people thought. Someone may find it useful! *
    Some images:
    And the download is here:
    Download
    Quick instructions:
    Unzip somewhere, you may need to set some paths for external apps in settings.ini, and edit topmenu.ini with your media paths (you can add/delete paths as well). systemmenu.ini defines the main menu screen.
    Then run project1.exe (I haven't come up with a name). If you want to set up the music database go into the database screen and select the paths you want to scan.
    Operation is pretty simple (or so I like to believe). You can also long press a folder to recursively play all the songs in it, and if you long press a song it'll queue it after the current song.
    Oh, and at present there's an issue with sqlite on my M9000 board - it don't work! Would be grateful if someone else could try this out. Works on everything else I've tested it on. Actually there's probably plenty more bugs. Who knows?
    Enjoy!
    itma_its_easy
    * (hoping that someone likes it enough to redo the graphics for me........! ;-)
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    looks good mate, certainly has potential!
    Newbie VorTechs's Avatar
    Dec 2007
    Gloucester, UK
    Out of curiosity, why doesn't it run FLAC\OGG\WMA?
    If you are using the bass library, all you need to do is download the plugins and make sure you use the correct API to load all plugins and you should be good to go!
    Unless of course you coded it in such a way that you are referencing plugins individually - which you don't need to do, BASS will play any file it has a plugin for!
    Otherwise, nice simple interface, I like it!
    KimmyBean> Stu, you know that cybersex we had?
    KimmyBean> I'm pregnant!
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Quote Originally Posted by VorTechs View Post
    Perhaps he do not need support for FLAC, OGG and WMA?
    fMod is even simpler.. No plugins needed at all, and plays everything!
    Nov 2007
    Crinos is quite right! I don't actually have any flac, ogg or wma files so I haven't even looked at supporting them, though I am aware that BASS does! As for fMod, I'd never even heard of it but from a quick search it looks pretty promising.
    Thanks for the comments.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This frontend is very light and that love that.
    Very good job.
    Please continue it
