Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 53
Thread: Nitro frontend is now in beta test
  1. #31
    Dec 2010
    Quote Originally Posted by Cham View Post
    Does it support sygic drive or sygic fleet??
    I tested it with Sygic Fleet, which actually has the exe and folder still named "Drive".
    However it should probably work with both.
    Please note that "supported" just means that it is automatically recognized and it's known to display properly. It is possible to embed any program so you can try to add GMPC if you want:
    Settings > User Interface > Menu buttons > Page X > Button X > External application
  2. #32
    May 2007
    Hi
    I got it to work now but sygic opens as a small window. How do i set it up so it opens up to the correct size.
    Also does the music mute when sygic speaks?
  3. #33
    Dec 2010
    Hi
    I can reproduce your problem by running the Nav as an external application, don't know why it doesn't work in that way.
    For the moment i would suggest you to put Sygic in the one of the paths of my previous post so that Nitro can find it and embed it. This kind of integration is usually slightly better as Nitro does a little more to improve the embedding since it recognizes the application, in fact in this way it works properly.
    At the moment muting audio while the nav speaks is not supported. It's not easy to do as there is not direct way of detecting when it's going to output the audio, i have examined some possible solutions but i wasn't really satisfacted with them.
  4. #34
    May 2007
    Hi
    I did put it in the correct path but it didnt' detect it.
    Then i went to the menu button setup and selected the sygic button which got it working but with the smaller window. Not sure whats going on.
    I guess you'll need the sygic SDK to develop the muting which is expensive to get
  5. #35
    Dec 2010
    Hi
    Uhm, that's strange. I have Sygic Fleet 8.30, what about you?
  6. #36
    Jan 2012
    No matter what I do this app crashes when loading for me in windows 7 64bit. I tried 32bit in virtual box but it failed there as well. (Different error). I'll put up the info windows gives me tomorrow when back in front of the PC.
    Sent from my MB860 using Tapatalk
  7. #37
    Jan 2012
    Not sure if there is another log somewhere (I couldnt find one) but below is what Windows 7 shows as the "Problem Details"
    Problem signature:
    Problem Event Name: CLR20r3
    Problem Signature 01: nitro.exe
    Problem Signature 02: 1.0.1.0
    Problem Signature 03: 4f15cec0
    Problem Signature 04: NLog
    Problem Signature 05: 2.0.0.0
    Problem Signature 06: 4e23d22d
    Problem Signature 07: 221
    Problem Signature 08: 6
    Problem Signature 09: System.TypeInitialization
    OS Version: 6.1.7601.2.1.0.768.3
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
  8. #38
    Dec 2010
    Quote Originally Posted by SiGO View Post
    Problem signature:
    Locale ID: 1033
    Seems like a serious error which is happening even before the Logger/Crash reporter are initialized.
    You should be able to find an entry in the System Log which the .NET runtime creates when an app crashes.
    Control Panel > Administration Tools > Event viewer > Windows Registers > Application (or System?)
  9. #39
    Nov 2007
    This will happen if you have an exception being thrown from a type initializer (aka static constructor) or from the code that initializes static members of a class. If you've got any non-trivial logic in either of those, look for ways that it might throw.
    Example:
    public class MyClass
    private static SomeType foo = new SomeType();
    private static MyClass { SomeOtherType.DoSomething(); }
    If the constructor for SomeType or throws, or if DoSomething() throws, the code caused MyClass to be initialized will get hit with a type initialization exception.
    I think you get the same exception if there's a circular dependency among your static initializers, too.
  10. #40
    Jan 2012
    Ok.. so from eventviewer I get this...
    Code:
    Faulting application name: Nitro.exe, version: 1.0.1.0, time stamp: 0x4f15cec0
    Faulting module name: KERNELBASE.dll, version: 6.1.7601.17651, time stamp: 0x4e211319
    Exception code: 0xe0434352
    Fault offset: 0x0000b9bc
    Faulting process id: 0xf90
    Faulting application start time: 0x01ccdfeba40f5a9a
    Faulting application path: C:\Program Files (x86)\LogiZee\Nitro\Nitro.exe
    Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
    Report Id: f25f4acf-4bde-11e1-a093-80253c9ed42d
    And this....
    Code:
    - System
      - Provider
       [ Name]  Application Error
      - EventID 1000
       [ Qualifiers]  0
       Level 2
       Task 100
       Keywords 0x80000000000000
      - TimeCreated
       [ SystemTime]  2012-01-31T07:41:12.000000000Z
       EventRecordID 3940
       Channel Application
       Computer Notebookius
       Security
    - EventData
       Nitro.exe
       1.0.1.0
       4f15cec0
       KERNELBASE.dll
       6.1.7601.17651
       4e211319
       e0434352
       0000b9bc
       f90
       01ccdfeba40f5a9a
  1. TPMS Beta Test
    By optikalefx in forum mp3Car Forum Made Product Reviews
    Last Post: 07-21-2009, 09:41 AM
  2. BETA Test....
    By guino in forum Road Runner
    Last Post: 07-26-2005, 09:25 AM
  3. Pre-Beta Test Update (Beta-testers please read!)
    By GTC in forum Software & Software Development
    Last Post: 06-13-2003, 04:02 AM
  4. Beta Test 1.6.9 Available
    By CarComp in forum ME Archive
    Last Post: 12-10-2002, 10:59 AM
  5. NNS MP3 Software beta test
    By Ashlawn Kemling in forum Software & Software Development
    Last Post: 08-21-2002, 12:57 PM
