It's up on sourceforge (http://sourceforge.net/projects/headunit).
If you have problems accessing source through CVS, try (with empty password):
Code:cvs -d:pserver:anonymous@cvs-pserver.sourceforge.net:80/cvsroot/headunit login cvs -d:pserver:anonymous@cvs-pserver.sourceforge.net:80/cvsroot/headunit co headunitI use gentoo, but it should work fine with fedora. Read the INSTALL file for compile instructions. You need to have the SQLite driver for Qt (instructions here: http://doc.trolltech.com/3.3/sql-driver.html#QSQLITE) and make sure your xine-lib was compiled with sdl support. The fedora RPMs may already have these compiled for you, so try it out before you re-compile anything.Originally Posted by mobileh1
LinkBack URL
About LinkBacks
I'm actually going to change over to FrodoPlayer skins since they allow for more functionality than the MediaCar skins. Actually, I will probably use the MediaCar main menu skin and frodo's player and playlist editor skins.
