Just to verify that the skinning code works correctly, I tried out more mods' Alpine skin. I have to fix the font code so that they are loaded properly, but here is a screenshot:
mobileh1,
I'm glad to hear you got it running! Thanks for pointing out the "~" issue, i'll modify the INSTALL file. There are plenty of bugs to fix right now. Some important ones:
* when one file stops playing, the next one doesn't start
* no fast forward, rewind
* double clicking on a file in the playlist doesn't play it
* DVD playback screen doesn't register mouse clicks
* Some files cause the database initialization to hang (probably have to check for bad characters in filename or something)
If you think you can help me fix these bugs, let me know and I'll give you write permission to the CVS tree.
stevieg, I'll work on getting framebuffer working as soon as I get some free time. But I agree with you, it is a much better alternative to running a full blown X server.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
NoPistonPC, What are plannign to name this software ?
Thanks for DESTIN![]()
DICE Los Angeles
Is this program set to be called xCar?
DICE Los Angeles
thanksOriginally Posted by NoPistonPC
Sweet deal man, I was going to test it out with College Linux on my other partition, but none of the mirrors have your file on them yet. Can't wait.
Got the CVS , I'll fiddle with it later and let you know.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
yunusyu, i haven't put much thought into it, but for now, it's called "headunit". If anyone has any better ideas, let me know...
pudge, i'm very interested to know if it compiles on your distro. i think as long as you have the latest qt, xine-lib and sqlite libraries, it should work. make sure you read the INSTALL file.
I'm installing QT as I speak, and SQLite and xine are next. I'll let you know.
edit:: QT takes a longggg time to make. Also, I saw your avatar and didn't get , and I just noticed you have an RX-7 lol.
2 Kicker Comp 10"
Check it out?!
1.3 liters of rotary power!Originally Posted by Pudge
(and one apex seal that's seen one too many detonations
Yeah Qt is big. Did you make sure to include all the configure flags listed in the INSTALL file? The important ones are -plugin-sql-lite and -pthread. Also for xine-lib make sure you --enable-sdl. Good luck!
