Originally Posted by NoPistonPC
SOLD! :D I just tested it with Qt/Embedded using the framebuffer and it works perfectly (after some tweaks to the source code). Actually it seems to run a bit smoother and of course doesn't require the loading of an X server, so from a cold boot you can start listening to music a lot faster. There is a minor issue with video playback taking over the entire screen (no control panel), but I am about to try out directfb instead of fb. This should make it easier to run multiple windows at once (so the control panel will work).
I will check in the code changes to CVS as soon as I get the video control panel working with directfb.
