Wow! I'm honouredOriginally Posted by NoPistonPC
I would really like to try Linux because I heard it's more stable, boots faster and all, but haven't got the time and enough motivation. But yeah, I'm open to skinning. Just let me know when. And I hope you will finally port it back to Windows for people like me
Cheers!
LinkBack URL
About LinkBacks
I just tested it with Qt/Embedded using the framebuffer and it works perfectly (after some tweaks to the source code). Actually it seems to run a bit smoother and of course doesn't require the loading of an X server, so from a cold boot you can start listening to
I'm actually going to change over to FrodoPlayer skins since they allow for more functionality than the MediaCar skins. Actually, I will probably use the MediaCar main menu skin and frodo's player and playlist editor skins.
Then thought about GPS, the WINE stuff wouldn't run, would it in the framebuffer? Or would it? Or could it be 'hosted' in a hidden X session? I really need to get a test box set up so I can play with what you've done so far!
