Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 71
Thread: My custom frontend
  1. #41
    Raw Wave tj!2k4's Avatar
    Oct 2004
    simple... very clean.. very nice..
  2. #42
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by walttoinfiniti
    This is looking very good!
    Others might want a more, but for me this is about all that I would need in a car computer.
    I only had a chance to try it quickly, been very busy at work, so this might be something I did wrong. I located a subdirectory with .mp3 files, but they did not show up.
    Before you waste your time looking into this, let me try it again later tonight.
    Your app is on my laptop and I am trying to get a project taken care of which had to be almost totally redone.
    Did you do the graphics?
    An BTW, was able to get XM working. Thanks for your help!!
    Walt
    Ok, i think i may have screwed up the example in the readme. here's a new example:
    I have a folder, full of folders (albums), that are full of mp3's. c:\music\Metallica - S&M (1999) The MP3 path should be set for c:\music and when you get into the MP3 player, you need to click the folder button and then click on Metallica - S&M (1999) and then select to start playing.
    I've been working alot on it tonite, and have got it so that you aren't allowed to select empty folders (you can click the button, but it just beeps) and that should keep it from erroring out.
    I'm prolly going to post up my work from tonite a little later. I've got the MPEG player working, but there's something that's messed up on my carpc, so it's taking like 20 seconds to load music videos, and random hanging and such. I've also noticed it getting a little slower lately anyway, so I'm copying the media offa it as i write this, and am formatting it over the weekend. I won't likely be doing any further development until carpc is better, and at that point, the XM is next on the TODO list.
    Another thing, I'll be needing a name for the software. CarPC is rather generic, and I'd like to have this software have it's own name. I don't want anything too fancy, altho anagrams are cool (like V.O.I.C.E.S.) but it's gotta make me want to use it. Post your submissions here.
    Keep the feedback coming!!
  3. #43
    Feb 2005
    Barrie Ontario
    Another Update:
    Got the MPEG player working, but to to major issues with my CarPC, and performance probs with video playback, this one is use/try at own risk:
    http://s37.yousendit.com/d.aspx?id=1...H08T0AVP10XDEB
    Extract and replace the CarPC7.exe
    Trevor
  4. #44
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    So how about XM, is that working?
    肚子笑痛了
    S60 Install
  5. #45
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by jcdillin
    No XM yet. Lemme get my poor carpc reinstalled, and I'll get to work on it
  6. #46
    Feb 2006
    Dallas
    FYI,
    Tried the mpeg viewer, but whenever I go to a directory with any video files I get a
    "Runtime error 5
    Invalid Procedure call or argument"
  7. #47
    Feb 2005
    Barrie Ontario
    ok, were you setting the MPEG Path in the options to the folder containing the files, or the folder that contains the subfolders that contain the videos?
    in my mpeg path folder i have several subfolders to divide my vids by type (Music Vids, CSI, Other, etc) with the vids in each subfolder. Set the path to a folder that contains at least one subfolder with your files in it.
    Hope this helps
    Trevor
  8. #48
    Feb 2006
    Dallas
    Tried again, I created a directory called videos and inside of it I created 3 subdirectories vid1, vid2, and vid3. Each have a couple of mpg files. I selected h:\Videos in the options and saved.
    After pressing the mpeg button and then the folder button I am at h:video and see the three vid subdirectories under it. If I select any subdirectoy I get a 'Runtime error 381 Invalid property array index' dialog box. Clicking on it causes the program to end.
    Walt
  9. #49
    Feb 2005
    Barrie Ontario
    make sure you double click the vid1, vid2, etc. Just single clicking doesn't work. I'm thinkin i may go to the same style as the MP3 folder chooser as it doesn't require the double click
    Trevor
  10. #50
    Pz_
    Pz_ is offline
    Feb 2006
    Indianapolis
    Dang, I missed the 7 day window. Any way I can still get a copy of this?
  1. Replies: 35
    Last Post: 07-11-2006, 07:07 PM
  2. Destinator 3 Frontend v1.1.3 BETA
    By Ninja Monkey in forum Map Monkey
    Last Post: 07-19-2005, 07:42 AM
  3. Need Custom logo How-to
    By kyjoe in forum Road Runner
    Last Post: 07-09-2005, 05:13 PM
  4. Destinator 3 Frontend v1.1
    Last Post: 10-25-2004, 11:40 PM
  5. custom case fabrications
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-10-2004, 04:43 AM
