Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: CarMM with OBDII interface
  1. #11
    Low Bitrate jnafpas's Avatar
    Feb 2006
    Greece near Delphi
    Wow,
    is this possible!!! Are you sure you have the right setup file ? Try to download and setup again. You have to get a succesfull message after installation. If you still have problems please send me a printout of the c:\program files\carmm directory by running the command "dir >out.txt " in command prompt.
    Send the out.txt file to john@skamnos.com
    Sep 2005
    ok, this the printout of my "program files/carmm" directory. Since my computer is in spanish, that directory appears in my pc as "Archivos de Programa/ carMM"
    Directorio de C:\Archivos de programa\CarMM
    13/02/2006 09:02 a.m. <DIR> .
    13/02/2006 09:02 a.m. <DIR> ..
    09/02/2006 09:56 a.m. <DIR> Beattle
    05/04/2005 01:00 p.m. 1.157 Beattle.skn
    09/02/2006 09:56 a.m. <DIR> Blade
    05/04/2005 01:00 p.m. 1.157 Blade.skn
    09/02/2006 09:57 a.m. <DIR> Bugatti
    25/10/2004 09:02 a.m. 1.155 Bugatti.skn
    04/02/2006 02:45 p.m. 3.738.112 CarMM.exe
    09/02/2006 10:05 a.m. 64 CarPc.ldb
    09/02/2006 10:05 a.m. 258.048 CarPc.mdb
    09/02/2006 09:57 a.m. <DIR> DefaultCarPc
    05/04/2005 01:00 p.m. 1.157 DefaultCarPc.skn
    09/02/2006 09:57 a.m. <DIR> Ferrari
    05/04/2005 12:56 p.m. 1.159 ferrari.skn
    12/02/1998 04:54 p.m. 149.504 MPEGDLL.DLL
    22/03/2004 02:27 p.m. 162.170 obderrors.txt
    09/02/2006 09:57 a.m. <DIR> Opc
    05/04/2005 12:56 p.m. 1.159 opc.skn
    13/02/2006 09:02 a.m. 0 out.txt
    12 archivos 4.314.842 bytes
    8 dirs 4.528.771.072 bytes libres
  3. #13
    Feb 2006
    Greece near Delphi
    Ok I think i know,
    you are using spanish windows... you have to setup the odbc to look to correct directory.
    Go to the control panel-> administrative tools->Data sources(ODBC) and configure the datasource "CarPc" to C:\Archivos de programa\CarMM\carpc.mdb
    I hope that will help
  4. #14
    Sep 2005
    Hi, I didi that, and the prblem is still there, I install the software, point the The data source to the correct destination, and when I open CarMM, i get only this:
  5. #15
    Feb 2006
    Greece near Delphi
    Hi,
    i created a new setup file. Please download and setup again. Tell me if you getting any messages when the app is strarted
    Sep 2005
    hi, it worked!! i only had to chance ODBC settings to poin to the right directory
  7. #17
    Feb 2006
    Greece near Delphi
    Very happy about that
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 08:32 PM
  2. OBDII Diagnostic Solution for $64 (+shipping)
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-11-2007, 06:54 PM
  3. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 03:36 PM
  4. OBDII CAN interface
    By nappyjim in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-14-2005, 03:02 AM
  5. FS: OBDII diagnostic interface
    By deskcom in forum Classified Archive
    Last Post: 12-09-2004, 11:24 PM
