Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: PocketPC as a Touch Screen Replacement
  1. #51
    Mar 2005
    NY
    What model PPC are you using?
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  2. #52
    Jun 2004
    The North, Manchester
    Dell Axim x50v
    Installed memmaid 1.72 last night - appears to be a bit better now.
  3. #53
    Mar 2005
    NY
    i have an x50. I believe you have more in your RAM then you expect. Are you saving your docs and files to built in storage? CHeck to see if you dind't accidently make any surprise recordings.
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  4. #54
    Jun 2004
    nope - hardly anything in built in storage.
    Bloody thing has wiped my SD card now, though.
    (using 2GB CF card and 1GB SD) CF for Music and SD for proggies.
    Since trying this setup ive had alsorts of probs with the SD card so gonna bin it and install all apps on CF card also. any ideas why this might be happening?
  5. #55
    Mar 2005
    NY
    has this been happening often? I try to keep as many programs and docs as i can in the built in storage. I'll let what slips into the ram slip into the ram. SD cards is music and vids, basically stuff that i can afford to lose. Also, if you're using sandisk cards, they had a tendancy to format themselves.
    your RAM though, that's what you want to have free as possible. how much is avaible therE?
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  6. #56
    Jun 2004
    after memmaid about 14MB, is that good by any standard???
  7. #57
    Mar 2005
    NY
    go to find, leave the search fields blank, and have ti search for files over 64KB (its an option). Any file that's not in storage (there'll be a weird little icon imprinted ontop of the file type icon) is in your RAM. see what you get and get back to me. with 14MB left, you will only have 5 MB for storage and programs...that is unless you have 28MB and then you go into Settings>memory settings and adjus the slider to give you more program memory than storage memory.
    Hey bill, i see you're also here looking at this thread right now, do you have any interest in this at all?
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  8. #58
    Jun 2004
    thanks for all the help on this.
    Ran the search fine but mostly pulled proggies and mp3's.
    Couldnt see any of the wierd icons you describe tho.
    for info, whenever i move the slider it resets itself after about 10 sec is this right as it seems useless!!
  9. #59
    Mar 2005
    NY
    lol, that's frustrating!
    This is what i want you to do. You're going to back up your PPC. Go to Progams>Back Up Data> Select all data (not just PIMs) and back it up to a flash card. Do it on the CF card as it will probably be faster and it will retain a little better as you've had problems on the SD card. When its done, HARD RESET your pocekt PC and then tell me what you get. Yes, you probably will be like, what the hell, but restoring your data takes like 8 minutes if you so choose. Also, back up your built in storage (manually copy and paste to CF). Bakc up documents or anything you want access to as this back up will be a fail safe and possibly may not be used again. Put the backups on a computer for safe keeping.
    Now, reinstally TOM TOM and a few slecet programs. Some will require main memory, others will be built in storage installable. Keep TomTom in main because it reads faster from there and you would want that speed (althoguht sintall map data on CF or SD). THen see what you get in terms of memory and everything. Keep an eye on the memory as you install your other programs you desire. Make sure it goes to the memory cards. Keep in mind that if you install 1 GB of programs,some files are reqiured to go to the RAM fo the PPC and that will fill up your ram as well.
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
  10. #60
    Jun 2004
    ok - upgraded my ROM the otherday since i found i was running A03. upgraded to A05.
    did all of the above, not getting anywhere between 13 and 19.
    I can run TT and MusicPlayer at the same time so for now im happy!!
    Why doesn't the slider stay where i put it. its almost like its a bug.
    Im running WM2003.
    Thanks,
    Nick
  1. Touch Screen replacement for OEM NAV - Infiniti G35
    By milpar34 in forum LCD/Display
    Last Post: 11-15-2005, 08:07 PM
  2. pc speaker beeps when touch screen is pressed...
    By tasteItheIvalue in forum General Hardware Discussion
    Last Post: 11-12-2005, 02:26 AM
  3. Need touch screen advice
    By sciff5 in forum LCD/Display
    Last Post: 05-29-2005, 10:58 PM
  4. Wide Screen format touch screen
    By belezeebub in forum LCD/Display
    Last Post: 03-22-2005, 11:35 PM
  5. task switching? touch screen only
    By chuckctv in forum Software & Software Development
    Last Post: 09-04-2004, 10:50 PM
