Evolution or Revolution????
http://www.carobd.com/forum/viewtopic.php?p=117#117
Printable View
im sorry if this has been answered but i cant find it on the site does it support all the protocalls iso pwm etc? and what is a good scanner to get to work with your software
thankyou
its looking amazing
Yes if your obd device is supporting these protocolls
When I start the frontend up, it says please verify Microsoft Data Access Componets 2.1 or later have been properly installed .
I checked that I am running the newest version 2.8 SP1.
Can you shed any light on this?
VaRMiT
??? You need only valid microsoft access odbc drivers. They are normaly already installed. If not try to get a ms-office installation.
Check out the newest version:
ELM327 support (Voltmeter)
Flash clocks from www.wrx-carpc.co.uk
Flash Games from http://elegans.imbb.forth.gr/games/
I really like your carMM front end. It is by far the best performing on my systems. Skins load super fast compared to RR and others (in my case 10 times faster).
Where can I get some user information? I'm having a hard time embeding Iguidance. I can't seem to make the movies play full screen. Not sure how to change skins. That's just the beggining.
Anyway, I'm excited that I finally found a front end that has the functions I want and performs well on my system I just need a little help getting it configured.
Hi,
you have to doubleclick on the screen to maximize the video playback. Doubleclick again to restore to the original position. If you want to create new skins just copy the <defaultskin2> directory rename it to another as example <myskin>. Then copy defaultskin2.skn file to myskin.skn and change the bitmaps and jpeg's in <myskin> folder.
You can choose the skins from the parameters window of CarMM2.
Have fun
Something went wrong when I changed the skin. I downloaded the HiFi skin from your webpage. I unzipped the files into the root of CarMM. This left a folder called Hifi (containing all the jpg's) and a HiFi.skn file I selected the hiFi.skn file from the parameter setup window within CarMM. I now have the HiFi skin overlayed with the default2 skin. Help
Hi,
you can't use the HiFi skin with version 2. Overwrite the hifi.skn file with the defaultskin2.skn file and copy the contents of the defaultskin2 folder to the hifi folder.
