Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 70
Thread: What would the ultimate front end be?
  1. #11
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I've thought about that, I wanted to do it in Java for that reason, so it would run on linux/windows/mac
    the problem with doing that is codec installers. Java's support for media files is at best poor! divx, realplayer, mp3's and all those need to be external players. So I guess a Java app could use external command lines that are configured, but I fear the multple OS testing.
    The second issue is using a GPS app. Again, Java can do this for windows using some ActiveX interfaces etc. But this will be a different game all together for macs and for linux.
    I'll give it some thought again, to see whether or not it is a viable option. I'll try a few proof of concepts first but I'm doubtful in all honesty.
  2. #12
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Quote Originally Posted by sama
    EHHH??? Javas media framework handle those AFAIK.
  3. #13
    Oct 2004
    NY
    ...I'll second the use of a database for speedy searches of huge music libraries... has to be easily searchable.... priority #1 to me...
  4. #14
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Actually my perfect frontend is browsing by either DB or folder list
    I found it faster for me to use folders for bands then the albums under them but only a select few frontends offer this.
    Id rather have that and a db but an option for either would be good
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  5. #15
    FLAC sama's Avatar
    Feb 2006
    London, UK
    @P3rv3rt B3ar - I looked at JMF recently, and focussed mainly on getting DVD to play through it. I was hoping for an out-of-the-box solution but faced many problems, and solutions out there use directshow wrappers, which would pretty much solve the video realm. Perhaps mp3's are implemented, I'm not too sure, but I'd bet a couple of dollars WMA and the likes are not as easy. I will investigate a bit more though. If you have any pointers for me, poke away
    @turbocad / Nin - The biggest problem is not the indexing itself, that part is easy and can be done in a variety of ways. The key is updating the indices. I know that in my case I have a removable disk that I take home and update. It would be possible to have an update on demand, but that would have to be a brute force mechanism to check thoroughly. This is a seperate area of debate I think and will probably be started as a thread of it's own when the project gets on the way.
  6. #16
    Sep 2005
    and what about using mono? is the opensource implementation of .NET ( and c#), and run in linux and windows
  7. #17
    FLAC sama's Avatar
    Feb 2006
    London, UK
    mono seems interesting. But I've found a lovely little gem: FOBS, a JMF plugin for FFMPeg, which is a multiplatform versatile player for divx/dvd/mp3's etc.
    I can't see any support for wmv/wma yet tho, still looking
  8. #18
    Variable Bitrate redbullah's Avatar
    Mar 2006
    Belgium
    sama says,
    "Back in the 386 days, some company made a game called Commanche, which loaded itself in that way."
    yes indeed nice commodore days.
    What about a Linux Carpc edition? Plus you can find anything you need on internet (like codecs etc) and free. I am almost sure that Linux can be modified for carpc.
  9. #19
    FLAC sama's Avatar
    Feb 2006
    London, UK
    after much thought, I still think doing it as a windows app is the best for one reason... drivers!
    Whilst I've managed to find enough info to get java working with all media formats now, there's still the phone controller, radio, tv and the likes, not to forget GPS.
    and even if the front end itself does work through mono, x-platform drivers will be cumbersome.
    so my verdict is that .net will be the way to go.
  10. #20
    Sep 2005
    Windows App only... sad to hear that....
    Support for multiple monitors would be a great feature..
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 04-12-2012, 07:29 PM
  2. 100% Plugin based Front End
    By custardbomb in forum Software & Software Development
    Last Post: 10-07-2005, 12:17 AM
  3. Searching for the right Front End
    By ninjatill in forum Newbie
    Last Post: 09-10-2005, 02:47 PM
  4. which front end for no touch screen?
    By turbochris in forum Newbie
    Last Post: 08-30-2005, 09:59 AM
  5. need a front end that runs at 640x480 ...
    By mattress in forum Software & Software Development
    Last Post: 06-09-2005, 03:44 PM
