I downloaded the trial version and found it very easy to setup and use (trial version is fully functional...it just has a 20min shutdown timer...nice thing is you can set everything the way you want it and test it out and if you like it pay the registration and enter the reg code and keep all your settings instead of downloading a full version and re-doing everything...Unless someone can point me to a more robust front end that is as easy to setup as it is I WILL BE BUYING IT FOR MY FRONT END (in the process of building my car pc-a little at a time over the next couple of months)...I downloaded it and installed it on my carpc cpu and just used my mouse and my desktop monitor to test it with (If you install it on your desktop to play with it just don't have it install a shortcut in the startup directory or you will have to close it out every time you start the pc up.) Will try to let you know more when I get everything installed and really test it out with an actuall touch screen.
LinkBack URL
About LinkBacks
