View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 12 of 69 FirstFirst ... 234567891011121314151617181920212262 ... LastLast
Results 111 to 120 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #111
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No problems. If you can find any more cameras from the Netherlands I would appreciate it.
    Also if you can check the ones are there match up to what I have listed in the first post it would be great.
    Cheers
    E.
  2. #112
    Nov 2004
    St Louis
    Quote Originally Posted by Enforcer View Post
    Cheers, that's good to know it works for others, there's always that worry that it won't work out there in the wild, no matter how much testing you do.
    I would be easy to add, seeing as the program can already reread a database. I would also need to add extra sections for preset cameras for each country in the ini. Hmmmmmmmmmmm
    The update function worried me at first. I saw the red dot but it never did anything. On my dev machine, I let it sit for over an hour after the red dot appeared, saw some internet activity, but it stopped pretty quickly. I realized later that it was done; but for some reason I was expecting the dot to turn green. I also (after some playing around with the DFX skin) realized that I had to completely exit the skin before the new database was recognized.
    Ran the update on my other 2 CarPCs, no problem. Great work!!!
  3. #113
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks for the new version. Its great. Everything worked perfectly until I started to mess.
    I'm trying to skin it in 800*480 but everytime I go to search I get a clip region boundry error. This is using the original .eskin but smaller jpgs.
    Any help would be greatly appreiciated.
  4. #114
    May 2006
    Calgary, Alberta
    So what exactly does this do?
    I'm going to take a guess and say it uses your Wi-Fi connection to get on the internet and stream media from live webcams you click on relative to your region. That right? So you need the internet?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  5. #115
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by GizmoQ View Post
    You don't have to exit the skin for th enew database to be recognised, just click the red dot. Does mention this in the readme
    Quote Originally Posted by lambosprit View Post
    Have you changed the skin size in the ini file, the ini file in the skin folder takes precedence
    Quote Originally Posted by Maheriano View Post
    It downloads still pictures at intervals set by the user in the ini file. I haven't managed to utilise streamed cameras yet.
    with the static ones updates vary from site to site, some as quickly as a second, others take 5 -10 minutes before they update, all depends on the supplier.
    And yes, you need a live internet connection
  6. #116
    lambosprit's Avatar
    Sep 2006
    UK
    Yeh. I had changed the skin.ini. I've attached my skin directory along with the trafficcams.skin I've made. Could you have a look please (and possibly add it to your install ).
  7. #117
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, you need to change virtually all the button positions in the search eskin to match what you have as a jpg, also the listbox doesn't match up, you need to change that as well. Make sure that at no time y position plus height exceeds your declared skin height. Same applies to x position and width.
    I guess I should put in some error checking for that.
    *edit and another thing the cameras on the main screen are squashed and go of screen so you need to check those as well. And I have no idea where the exit button is on your main screen either.
  8. #118
    lambosprit's Avatar
    Sep 2006
    UK
    Thanks for all that. Got a bit mixed up in my versions. Sorry for the time wasting. Fixed the problem with using your x and y calcs though so thanks.
    My screen exits from another button on the trafficcams.skin. I'm using the Freedom ultimate skin which has a music bottom bar with an exit button.
    Think I've sorted the squashed bottom cameras but have a problem with my search skin still. The up button doesn't work until I've used page down and the button area doesn't seem to match the coordinates I've put in the skin.
    Could I trouble you to have another look. Thanks again. Its greatly appreciated (and I've checked I've attached the correct version this time)
    Attached Files Attached Files
  9. #119
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, I've had a look, and found out the up button doesn't work on the first page and the down button doesn't work on the last page (both now fixed for next update) due to me not coding it. I knew there was something I meant to go back and finish.
    As for your button not in the right place, still looking. (edit, OK sussed what that was. Also fixed)
  10. #120
    Nov 2006
    Enforcer,
    Any chance of adding the Louisville, KY cams from page 7 of this thread? I would really like to add your plugin to my carpc as traffic is a *itch in the mornings going to work.
    Commell LV-671M 2.0ghz Intel Dothan 512MB SDRam
    Xenarc 800TSV Touch Screen, MiniPCI Intel® PRO/Wireless 2200BG w/External Antenna
    GlobalSat BT338 GPS, Linksys USB Bluetooth Adapter, Opus 250 PS
    Road Runner, Freedom Ultimate, iGuidance 3.0
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-23-2007, 12:10 AM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 10:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 08:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 02:55 PM
