View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 17 of 69 FirstFirst ... 78910111213141516171819202122232425262767 ... LastLast
Results 161 to 170 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #161
    Jun 2007
    NY
    I ran register.bat,, however when i try to run trafficcams.exe I get an error "MSINET.OCX or one of its dependencies is not registered or missing"
  2. #162
  3. #163
    Jun 2007
    NY
    I've tried it on IE7 and IE6 , 2 different computers, it seems the MSINET.OCX file is not installed anywhere on my PC's.
    I found a copy online, i was able to register it, and get trafficams.exe started.
    I modifed the ini file to change country to US, program starts , now i guess its a matter of learning how to use it. It seems to be getting cams from another country, the display is not centered, so I can't see everything and presumably menu options.
  4. #164
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Press the magnifying glass, that will take you to another screen where you can select which cameras you want to view on the main screens.
  5. #165
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by tonystoolroom View Post
    Im getting the same thing. I had Cams running successfully on the old ver. upgraded to this one, loaded all the cams and evrything looked good. X out and loaded cams back up and received that same message.
    If you cant DODGE em, RAM em.
  6. #166
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK have realised what that is.
    I added something for different types of cameras and and didn't realise that that does get registered. Will add that to the register.bat I guess.
    in the meantime try
    regsvr32.exe C:\WINDOWS\SYSTEM32\MSINET.OCX
    or
    regsvr32.exe C:\WINDOWS\SYSTEM\MSINET.OCX
  7. #167
    Newbie Robterza's Avatar
    Dec 2005
    Rome
    Quote Originally Posted by Enforcer View Post
    Because of the many different ways that sites operate their traffic cams, and also the potential resource hog I have had to make a few decisions.
    The way the program basically works is to download an image from a specified URL, most of the time these are static images which can be updated(refreshed) on the website anything from every second up to 20 mins or even more.
    Because different sites have different times there is a setting in the inifile to change how often the program checks for a new image. This can be set as low as once a second.
    However because there is anything upto 18 cameras being monitored, by the time each url is checked and the image is downloaded they may not update every second.
    Also the more often you update the more processing done by the CPU, the more data is downloaded, so it is kind of a trade off.
    I could look at using a browser window for each camera that works like the one you posted but then it will take up more resources and not be a skinnable or nice looking.
    BTW the image you posted is just a few frames in a gif, not sure if it 'live'
    Ok, so the cars should not move in rr. Only refresh pictures when downloading a new one.
    Anyway, I found this, http://www.quattroruote.it/telecamere/index.cfm for a few italians cams,Hope the codes are good.
  8. #168
    Jun 2007
    NY
    if anyone needs the MSINET.OCX file you can download it here:
    http://www.afreeocx.com/ocx/info/msinet_ocx.html
  9. #169
    Jun 2007
    NY
    whats the proper screen resolutions settings for lets say a 8" Lilliput monitor running at 800x600. The Trafficams display is getting cutoff on the right hand side.
  10. #170
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Robterza View Post
    I'll check them out, probably won't be till the weekend though.
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-23-2007, 12:10 AM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 10:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 08:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 02:55 PM
