View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 18 of 69 FirstFirst ... 891011121314151617181920212223242526272868 ... LastLast
Results 171 to 180 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #171
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by tonystoolroom View Post
    if anyone needs the MSINET.OCX file you can download it here:
    http://www.afreeocx.com/ocx/info/msinet_ocx.html
    I've included it in the download, plus the register.bat.
    whats the proper screen resolutions settings for lets say a 8" Lilliput monitor running at 800x600. The Trafficams display is getting cutoff on the right hand side.
    the current skins are both set for 800 width, so should be fine.
    You can change the width and height but then you would need to redesign the skin files as well.
  2. #172
    Jun 2007
    NY
    the default ini file settings are :
    [General]
    Width=800
    Height=546
    Delay=60
    Country=IS
    Skin=Default
    Update=4
    so I am tinkering with the width to try to see the whole screen. I'll give a width of 600 a try. I'm not using a front end program.
  3. #173
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    there are settings in the skin file (in your case default) they will overide the ones in the ini file there.
    If you change the width the you will have to adjust the skin files as you may chop off the buttons.
    Actually I have just realised what the problem might be, the program doesn't load at 0,0 if run alone. Let me adjust the exe and see if I can get you a new version that will allow you to put it where you want.
  4. #174
    Jun 2007
    NY
    ok cool
  5. #175
    Aug 2006
    Hey!
    Amazing plugin--I'm really impressed.
    I found a website for some traffic cams in Raleigh, NC. Think you can add some support to the capitol city?
    http://www.ncdot.org/traffictravel/c.../triangle.html
    Thanks a bunch and good job again on the great work!
  6. #176
  7. #177
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Talking
    Quote Originally Posted by Enforcer View Post
    It's probably best you download the latest 1.19 version.
    It seems your firewall is causing a problem with the automatic updates.
    OH and you set the refresh time of the cameras to over 27 hours.
    Enforcer...
    I have downloaded the latest version 1.19 and it works fine now.
    I thought I read this somewhere that this does not work in other formats but 800x600(546).
    I might be one of the few that run my front-end in 640x480. In the future, will you add 640x480 format?
  8. #178
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    E - Sent you some updated IOM cams.... this time I've included the lat / long for you.
    Terran
  9. #179
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by navputer View Post
    Enforcer...
    The program is not dynamically resizeable (ie it won't chage size as a request of the front end), however if you re skin it, you can make it any size you like. The skinning is done very similar to that of RR.
    I will look into making future versions change size at the request of a FE.
  10. #180
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ccsnet View Post
    Terran
    OK, will take a look.
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-22-2007, 11:10 PM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 09:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 07:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 05:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 01:55 PM
