View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 19 of 69 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #181
    Jun 2007
    NY
    I replaced the file msatuev.exe and added the line to the ini file, but when I run trafficams I get runtime error type 13 type mismatch.
  2. #182
  3. #183
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Great app, Enforcer!
    I don't see the Dallas, TX cams in the list (DFW) that were posted a couple of pages ago. Will you be adding them soon?
    If there is some data missing for them let me know and I'll give it a go. Looked like maybe the GPS data isn't there for them yet.
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  4. #184
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Quote Originally Posted by Enforcer View Post
    The program is not dynamically resizeable (ie it won't chage size as a request of the front end), however if you re skin it, you can make it any size you like. The skinning is done very similar to that of RR.
    I will look into making future versions change size at the request of a FE.
    Ok...tks
    I am assuming that I should use rrskineditor to re skin it, Correct? But I notice that you made the file extension .eskin.
    Thanks for all of your help....I will be excited when DFW area is added
  5. #185
    Newbie scaff's Avatar
    Feb 2007
    Not been here in a while so im reading back through many threads and updates I have missed.
    This software looks excellent just singed up to your board and awaiting validation.
    Thank you
  6. #186
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Zogg View Post
    Z
    They'e waiting to go through my DB creator along with the San Francisco ones, hope to get it doen over the weekend.
    Quote Originally Posted by navputer View Post
    Ok...tks
    No don't use rrskineditor, I have no idea what the results will be.
    the .eskin file needs to be edited in notepad or similar.
  7. #187
    Jun 2007
    NY
    Heres the ini file
    [General]
    Width=600
    Height=400
    Delay=60
    Country=US
    Skin=Default
    Update=1
    Xpos=0 Ypos=0
    [Cams]
    Cam1=IS00007
    Cam2=U40000B
    Cam3=IS0000B
    Cam4=IS0000D
    Cam5=IS00010
    Cam6=IS00034
    Cam9=U4000BF
    Cam10=E4000B8
    Cam11=E40001B
    Cam12=E400038
    Cam13=E400044
    Cam14=E400054
    Cam15=E400074
    Cam16=E400094
    Cam17=E4000A4
    Cam18=E4000F4
    Cam8=U4000BF
  8. #188
  9. #189
    Jun 2007
    NY
    ok, the program is running now. I only get a full view of your program if I set the desktop to 1024x768, otherwise it's off the screen at 800x600.
    I also don't see the red dot to update the database so I'll have to take a better look. What format are your database files in? I think it would be better to delete the records of cameras in areas I don't need, that way the list isn't so big to scroll through.
  10. #190
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by tonystoolroom View Post
    If you are running 800x600 and have set the xpos=0 and ypos=0 and are using any of the skins included then it should not go off the screen.
    post a pic.
    The database light will only light up if there is a newer version of the database, what DB version does it say you have at the moment.
    You can just type the city/state in the search bar, that will reduce the list.
    And the database format is my own format.
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-22-2007, 11:10 PM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 09:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 07:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 05:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 01:55 PM
