no way to register to your site, that code (the one on the registration section ) wont be accepted, try at least 25 times.![]()
Dummy 1
Dummy 2
Yeah unfortunately the only country that has cameras that update at a good rate is in the US. And even then it varies from state to state.
Which one do you mean, the visual one, or the one you have to go look for.
PM me.
NB I just tried and could register an account no problem, also there have been registrations from others since you posted above.
Aprobed what? I am not probing anything.
*Edit Activated, but why o why did you use a different username to the one here.
Your account is currently inactive, the administrator of the board will need to
activate it before you can log in. You will receive another email when this has
occured.
Please do not forget your password as it has been encrypted in our database and
we cannot retrieve it for you. However, should you forget your password you can
request a new one which will be activated in the same way as this account.
Thank you for registering.
Slovenia Database added.
Country code SI
Poland currently on test, but may have to wait to new version of program comes out.
Enforcer
I'm also having problems with the auth code on your website
will not let me register. Sent you an email
The code at fault is the one you copy from the box.
Cheers Paul
http://www.dot.state.pa.us/penndot/d..._map2?OpenPage
Here is the site that has all the Philly cams that would be very useful for us who do 95/TP/RT1/476 in the mornings and evenings. I however do not know how to match the cam up the coords... Can someone explain this to me, so we can get these cams added.If you view the HTML it shows the coords, though it doesnt have a link to the camera picture... though if you keep looking further down, the jpgs are there, but not sure how to match them...
Thanks!
Can you authorize me for your site so I can D/L the plugin!
__________________________________
The NEW Design : 90%
The NEW Install : 2%
The Aspirin : Alot!
