Dummy 1
Dummy 2
I will take a look at that site tomorrow. It uses google maps which is always a good thing for me as they usually contain the LAt and lon.
Account activated.
It actually looks fairly simple to get the GPS coords and url, the main issue is that there is no location description except in the jpg itself, so that bit could be tricky
I also noticed that there are a few other areas of Pennsylvania there so I will be collecting those cameras as well.
Just for anyone who might be interested in this , i have done the BVM2 skin in a 640x480 for my own machine so if anyone else needs it ill put a copy up - you may need to delete the irish info on it but its easier than playing about with the numbers.
This has to go into
C:\Program Files\Road Runner\Traffic Cams\skins for a standard location RR install.
I did not want bother on that, since u been helping others setup cams....tks though
Another note....
I am having a problem now trying to get Dallas, TX cams to work. It was working before but now when I go to search cams, I get the error message "Run-time error '53', File not found". I tried different cities (houston, new york, etc) but I did not get the error.
Is there something wrong with the Dallas cams?
Thanks for your help.
Dallas is working fine for me (except for one but it doesn't cause a crash)
does it crash straight after typing dallas and hitting search or after you have viewed a few of them?
check to see if you have a 'No image.jpg' in your traffic cams folder.
When I go through the list the following don't work (but the program does not crash)
IH30 @ CENTRAL EXPWY
IH30 @ IH45
IH635 @ TOWNE CENTRE
