View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 42 of 69 FirstFirst ... 323334353637383940414243444546474849505152 ... LastLast
Results 411 to 420 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #411
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    I do have the 'No image.jpg' in the folder. I will delete it to see what happens.
    When I get the error, I hit "Ok" and it closes out. I changed the delay to 10, 20, 30 but if I do 40 and above it works...still testing though to be sure.
  2. #412
  3. #413
  4. #414
    Jan 2007
    DFW Area
    Right, this is weird. It was working fine before. I did not use it for some time but when I tried this weekend. I got the message. So, I thought someone happened.
    Should I post a file for u to see?
    Tks...
  5. #415
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    can you post a directory list of your traffic cams directory?
    Also add
    Debug=True
    to the ini file and then attach the debug.txt file.
  6. #416
    Jan 2007
    DFW Area
    Ok...I will post the files.
  7. #417
    Jan 2007
    DFW Area
    *******FIXED*****Here are the files...tks
    EDIT: I found the problem....
    I went to MS site to lookup the error and it stated that the .dll file (unzip32.dll) needs to be in \windows\system32. So, I did not see the file there and I just copied it over. Now it works fine.
    NOTE: I did click on the register file as well.
    Attached Files Attached Files
  8. #418
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Strange that it needed to be copied over to there, as normally it works with it being in the directory the program runs from.
  9. #419
    Jan 2008
    Cant download
    Hi,
    I joined your forum a day ago and still cant get access to it? Not sure why this is.
    Michael
  10. #420
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by miak69 View Post
    Hi,
    Michael
    Because I haven't validated your account yet
    I don't have time to check it every day.
    Will validate now.
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-23-2007, 12:10 AM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 10:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 08:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 02:55 PM
