View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 44 of 69 FirstFirst ... 343536373839404142434445464748495051525354 ... LastLast
Results 431 to 440 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #431
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by brandensin View Post
    enforcer, tried to create an acct on the web site... failed to match the auth code
    Could you create me one please, so i can play with this gorgeous plug in?
    Thank you sir.
    by the way, who do you think is favor to win euro 2008?
    I would need an email account to enter. PM me details if you are still having trouble.
    Well C Ronaldo is in fine form at the moment so Portugal might be in with a chance, Germany can never be written off. Italy are the current world champs but are in with France and Netherlands. Spain will probably flatter to deceive and the Czech republic and usually solid.
    It's a tough one.
    I'll tell you what when I have put the finishing touches to my spreadsheet and put my predicted scores in I'll see how it pans out.
  2. #432
    Dec 2007
    Hmm... i am getting run-time error "5" invalid procudure or call...
    I registered all the ocx by both running bat and manually.. msinet.ocx was missing, so, i downloaded from here and registered that too... I don't know what else i can do..
    any suggestion?
    thanks..
    [General]
    Width=800
    Height=586
    Delay=59
    Country=US
    Skin=Default
    Update=6
    Xpos=50
    Ypos=150
    [Cams]
    Cam1=
    Cam2=
    Cam3=
    Cam4=
    Cam5=
    Cam6=
    Cam7=
    Cam8=
    Cam9=
    Cam10=
    Cam11=
    Cam12=
    Cam13=
    Cam14=
    Cam15=
    Cam16=
    Cam17=
    Cam18=
  3. #433
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OOh you have the new version as well.
    Hmm, let me take a look while at work tonight. (that's one of the problems with only testing the package on your development machine, all the dependancies are already there )
    *Edit, Hang on, why is the Update set to 6? should be a number 1-4 only
  4. #434
    Dec 2007
    i thought that was like refresh rate.. thought u recommended if net connection is slow then use higher number.. i tried with 3, 4... same result.. let me reboot my machine and try again..
  5. #435
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No, that's an internal setting not to be changed by the user. (Note to self, maybe move that to a different section for future versions).
    I will test the download on a 'clean' machine tonight
  6. #436
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, I have tried this on a fresh PC, and aside from having to register the OCX's it works fine.
    So I'm puzzled about your Invalid Procedure Call.
    If it still doesn't work, put Debug=True in the ini file anywhere in the General Section.
    and then post any debug.txt file you get
  7. #437
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    country code issue
    hello,
    I've put into the ini file de IT code
    [General]
    Width=800
    Height=586
    Delay=60
    Country=IT
    Skin=Default
    Update=3
    Xpos=50
    Ypos=150
    but when I launch the application the camera database is empty...
    Where Am I wronging ?
    thanks,
    pijo
    CarPC in Progress [||||||||-] 90%
    Visit my Project
  8. #438
    Nov 2004
    Novara - Italy
    ok.. sorry, I've understood...
    I've only to wait the download of the database...
    thank anyway.
    pijo
    Visit my Project
  9. #439
    Dec 2007
    Here it is...
    Attached Files Attached Files
  10. #440
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    That's RoadRunners debug file.
    I need the Traffic Cam one, it should be in the Traffic Cam folder if you put Debug=True in the trafficam.ini
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-23-2007, 12:10 AM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 10:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 08:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 02:55 PM
