Dummy 1
Dummy 2
No, what I meant was you wanted to be able to search within the search results.
eg
Find all cameras within OH
Then find all Sometown within those results.
Something I can look at adding.
Enforcer, please disregard. The cams in the "documented" text file are already in your database. I never finished getting the GPS Coordinates for the 25 cams on the Illinois side.
This attachment was meant for MachineHead, and yes it is a PITA to find the actual .JPG web addresses and then use whatever mapping software you have available to determine where exactly the cameras are situated. Some of them have recognizable landmarks and the pics pretty much tell you what direction the camera is pointed, but even comparing satellite data with the pics doesn't help in some locations cause they just don't seem to match. And aside from driving out to each site, it got frustrating. I am more familiar with the cams on the Missouri side so those are the ones I tagged with GPS Coords.
I tell you what, MachineHead, I'll go ahead tonight and map the IL cams and you let me know which others you need help with.
I guess I have to ask the dumb question, why are the GPS coords necessary?
The US database isn't searchable by map like the UK database is, at least as far I can tell from the whole 10 minutes I've played with it.
Nah... personally, I think that's overkill... The search one we have now is enough as long as it finds all, not missing anything... For example, if i search for Dallas, TX, then it should list all the cams in Dallas those ones registered in your DB. If i search for TX, then it should find all of the cams in TX..
I noticed not all of the dallas ones are listed and that's because no one has provided you the cood for them yet, not cuz search failed, right?
Also I didn't know the UK was searchable by map.
The other use is the ability to show where the camera is on the map when using the search page (Oh maybe you meant that, but the US has that, there are just not enough cameras with GPS coords for them all to show a map)
