View Poll Results: Poll removed
Voters
141. You may not vote on this poll
  • Dummy 1
    0 0%
  • Dummy 2
    0 0%
Multiple Choice Poll.
Page 58 of 69 FirstFirst ... 8484950515253545556575859606162636465666768 ... LastLast
Results 571 to 580 of 682
Thread: Traffic Cams International v1.3.0 (1.4 Beta available)
  1. #571
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    In your Hands
    Quote Originally Posted by Enforcer View Post
    Don't know why TC closes, but Roadrunner does disappear when you use the APPOSK for some reason (this is a RR thing not TC), but should reappear on hitting enter or ESC on the OSK.
    I'll have a look/play with your skin though.
    I am ,
    Thankyou
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #572
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, I have had a quick play with the new version and your skin files, outside of RR.
    Observations :
    I like very much interesting layout of the 'video wall', and the search screen with the two image screens.
    With that said I have some suggestion/observations.
    1. there seems to be no page indicator on the video wall screen
    2. on the video wall tweak the image position so they don't cut into the border (top corners)
    3. Don't forget to leave room on the info bar for Lat and lon (future edition)
    4. you have left out the time/data lst updated (no biggie, your choice)
    5. On the search screen the text box for inputting the search string is not obvious.
    6. Up and Down buttons on search screen seem to be reversed.
    7. The map screen is a bit small and causes one of the map buttons to drop. (see image)
    Also an observation for me. Need to make it such that f there is seperate map display it should update automatically, rather than need the map button to be pressed.
    Will get onto the above
  3. #573
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK, also just tried your trafficam.skin and png's in roadrunner with the OSK. As you say your buttons at the bottom disappear (ie roadrunner), but TC does not crash out.
    I would suggest that your OSK is sending a close, exit or main command when you hit enter instead of just ENTER
    Also to add to my list above
    8. When you type in a search string the text is not level with the word find, it is a little higher.
    9. You need to change the text in the trafficam.skin from "You need to install the Internal Traffic Cams Plugin" to "You need to install the International Traffic Cams Plugin" (I see you copied from John)
    Have now got it so that if you are using the second display for the map it will show a map automatically if there is GPS coords so you don't need the map indicator.
  4. #574
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i'll get
    on to it tonight.
    as for the osk i'm using the enter cmd so not sure what that is, but will look in to it.
    working on the rest as we speak , should have an update later on .
  5. #575
    Aug 2006
    Enforcer,
    Can you check the source for Palm Beach, FL.
    I get a message instead of the picture, telling me to go to http://www.palmbeachcotraffic.org/ to get the image and reports.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I am aware of that,and have had a look but they have been very clever in the way they make them inaccessable.
    I haven't given up but it may take some time.
  7. #577
    Aug 2006
    Thanks.
  8. #578
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    640 x 480
    Has anyone tried to run this @ 640 x 480.
    I'm using DFX3. I have changed the skin.ini under traffic cams/skins/digitalfx folder as the readme.txt says it overrides the Trafficams.ini setting. Tried changing that also.
    Everything else in DFX3 runs fine in 640 x 480.
    ...JJG
  9. #579
    Dec 2007
    how you guys able to run this other than 800x600? jpgs are not resizeable. so when you scale the skin down, it won't rescale the jpgs, instead it will cut the bottom and right... Is that correct, enforcer?
    By the way, this is my situation. I can run this and have my music display garbage(^$^%$&%), or music display proper unicode but, no traffic cam running...
    What do you say we make both work right Enforcer?
  10. #580
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    are you running
    Quote Originally Posted by brandensin View Post
    a skin other than 800 x 600, if so i can resize my TC skins down to fit your skin size.
    i was thinking of trying another skin size anyway for my whole skin,
  1. US Traffic Cams 1.0 Beta
    By Enforcer in forum Other Cool Stuff
    Last Post: 04-22-2007, 11:10 PM
  2. Navigation - International chars in streetnames.
    By Cirion in forum Centrafuse
    Last Post: 02-24-2007, 09:07 AM
  3. Replies: 0
    Last Post: 10-17-2006, 07:11 PM
  4. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 05:20 PM
  5. Traffic
    By RedGTiVR6 in forum GPS
    Last Post: 07-06-2006, 01:55 PM
