Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Access Control 1.4.x
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok this is another update to my additions to StevieG's Access control
    Original thread
    If you have not used this before it is suggested that you download and install the original version from the above thread and then unzip this one over the top.
    If you have used it either mine or The original, back up your settings.ini file first so you can copy your settings.
    Download
    New Features for 1.4.x
    Hibernate aware, will now pop up after hibernate/standby
    USB Key access.
    Pause Frontend at startup, resume at exit for FreeICE
    Added Config program for settings.
    Version 1.3.x
    Allow keyboard input
    Access via MS Fingerprint Scanner
    Version 1.2.0
    Pause RoadRunner Frontend at startup, unpause at exit.
    Changeable Font colour
    Background color setting.
    Transparent background for text input.
    Delay recording according to time or failed attempts
    Run external program batch/script after predefined failed logins.
    Multiple passwords leading to choice of startup programs.
    Delete key added
    Version 1.0.4
    Features:
    Audio recording
    Video recording
    Beep on keypress
    Voice announcements
    Audio & video recordings can be turned off and also set to record only after a set number of incorrect codes.
    Beep and voice commands can be turned off as well.
    Please backup original accesscontrol.exe and settings.ini file.
    Then download and unzip files to access control directory.
    Run register.bat
    Open settings.ini and change settings to how you want.
    Original Program :StevieG
    Beep on Keypress and Voice Announcements :Tissy.
    Original Centrafuse skin screenshot and also an iDrive one which is included
    Attached Files Attached Files
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have also collated a few of the skins which have been posted in the previous threads.
    I hope the authors don't mind me putting them in the new one.
    Also I would like to see and skins you have done for yourself that you would like to share with others.
    Angelina Jolie by gunner2382
    HiFonics by SierraRS
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    MrT by vatik
    Simplistique by Tissy
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    ST170 by StayFocusd
    Carwings by blk02si
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Metal by BTBE
    cf1.4 by tj!2k4
    Newbie Kadyroff's Avatar
    Sep 2007
    Moscow, Russia
    Sorry if I'm asking a stupid question, but...
    Did I get it right - for using Access Control 1.2.0 I need original version from StevieG to be previously installed? If yes, then the problem is that original version is not available anymore on his site. I will be highly appreciated if someone advises me where to download it. Thanx!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It should work on it's own, but just in case there is something in StevieG's installer that is needed I recommend that people install that first.
    try www.mobile-effects.com I believe they have an original version for download
    Under Misc on the left, you will have to register I am afraid.
    Sep 2007
    Moscow, Russia
    Enforcer, thank you for the link!
    Constant Bitrate BrianMay's Avatar
    Oct 2004
    Lisbon, Portugal
    the download link is broken...
    Virando costas ao mundo
    Orgulhosamente sós
    Glória antiga, volta a nós!
  1. AIMEE Climate Control POLL
    By Danceheaven in forum Software & Software Development
    Last Post: 01-14-2010, 10:38 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 10:42 PM
  3. M-Audio with ASIO volume control
    By mkysimes2 in forum Road Runner
    Last Post: 04-17-2007, 12:25 AM
  4. Using Access Control as a shell in XP
    By Angelus in forum Other Cool Stuff
    Last Post: 12-23-2005, 10:34 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
