Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Switcher - A little button app to Alt-Tab between two programs.
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Smile Switcher - A little button app to Alt-Tab between two programs.
    I made this real quick in VB .NET for a friend who wanted to Alt-Tab between Co-Pilot 2003 and Winamp.
    It's a small clearish button that Alt-Tabs between two windows.
    You can click and drag it around, and to exit - right click it.
    You will need Microsoft .NET Framework installed.
    You can download it here: Microsoft .NET Framework Version 1.1 Redistributable Package
    Here's Switcher.zip:
    Attached Files Attached Files
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Variable Bitrate wkolodny's Avatar
    DC
    Very nice. You jsut solved my problem.
    http://www.mp3car.com/vbulletin/show...5&postcount=72
    Would there be a way to either A) change the level of transparency and/or B) alter the icon?
    Don't Fear The Gurkey
    Click here to check out My Setup
    DC
    Dang. It doesnt seem to work when switching between frodo and copilot 7. It stays on top but doesnt switch the apps. Bummer.
    Jan 2002
    Long Island, NY
    I would have to recompile it to change the transparency and change the icon.
    I didn't make it variable. Again, it was made really quick.
    Sorry, it doesn't work with Co-Pilot Live and FrodoPlayer.
    Nov 2003
    Why do you need an external app to switch between copilot and frodoplayer? Just set copilot to show the taskbar and set the res of frodoplayer to something like 800x575. This way the taskbar is visible and you can switch between the apps by clicking on the taskbar button.
    Quote Originally Posted by wkolodny
    DC
    Quote Originally Posted by Izik
    How can I choose a that resolution in frodoplayer? I dont see it as an option? Unless you are talking about a custom skin?
    Nov 2003
    Change it manually in the ini file (near the bottom of the file).
    DC
    Doh. Thanks Ron.
    Newbie peegee's Avatar
    Oct 2004
    Massachusetts
    Well, having a slick transparent button switching between full screen apps is much slicker looking than having an ugly task bar down the bottom with the start button and the systray/clock etc...
    2002 Subaru Impreza WRX hatchback - Silver.
    IBM Thinkpad T21 800MHz 256Mb RAM 20Gb HD
    Lilliput 7", CoPilot, MediaCar
    Pyramid Super Blue PB442X 300w 4ch Amp
    Creative SB MP3+ USB
    Oct 2004
    Massachusetts
    Thumbs up
    Quote Originally Posted by LESLIEx317537
    Wow this was almost the solution for me too.
    but it only works some of the time for me.
    Its quite predictable though, maybe its happening to others too and you might be able to fix it for us? :-)
    It loads fine, and when i click it the first few times it will switch. But its hard to tell if its reacting to a one click or double click. After a few successfull switches it just flashes the "alt-tab" menu/gui up on the screen but doesnt switch. I kill the prog and start again and then the same thing happens - works once, twice, a few times and then stops working.
    Any ideas?
  1. How to make MP3 button launch external app?
    By Griffin_Dodd in forum MediaCar
    Last Post: 04-01-2004, 11:04 AM
