Page 14 of 25 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 246
Thread: Input tool using MouseWheel
  1. #131
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by zorro
    Did you check the path to the Applications?
    Yes. Tryed making them myself. I does work sometimes, but not all the time.
    One thing though. As I said, when using MWI, the scroll is also active, either you're on an internet page, or in winamp. Is there anyway to make the scroll wheel only for MWI, when MWI is running?
    For example, when in winamp, shuffling through MWI's menu witht he scroll wheel, it also togglles the volume in Winamp. Same thing when you're winamp's playlist. Using when scroll wheel in MWI also means you're surfing through the palylist...
  2. #132
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    In fact, MWI is programmed to block passing wheel messages to the system as long as one of it's windows is open.
    I've rebuilt the libraries in the setup package and put 'em online in a separate package http://phoco.net/__Bin/MWIProDllsOnly.zip
    Please download it and copy them over the existing ones.
    Skinning to go... VisualDesigner2!
  3. #133
    Romania
    Works fine now!
  4. #134
    Romania
    I finished the fabrication of the iDrive button. Inspired by TonyG, I decided to put an encoder in the button. Looks nice too. (can't see that, because of the phone quality of the pic) But the impulses sent by the encoder are a little faster than the ones by the scrool wheel, so is there any way I can make the scrool wheel not that sensitive from the software?
  5. #135
    Mar 2004
    Munich, Germany
    Looks hot man, even with the poor pictre quality.
    Yes, there is an option in the configuration called "SlowDown" the higher the value the less sensitive it gets.
  6. #136
    Romania
    Thanks! What can I say...Samsung's ideea about 1.3 MP...
    Good to know Zorro. Actaully now it works preety well, as I had this problem when I tested with it with the actual encoder. But now with the button on, it works well, as it's bigger in size, and it slows it down a little.
    Unfortunatly I have a new problem now...I don't know, it may be something I did, but I get this error when MWI starts...clicking "OK" wil only make it appear again...
  7. #137
    Mar 2004
    Munich, Germany
    This is a bug in the Configuration where the MWI window is set to Royalbue instead of Royalblue. If you correct this setting, the problem will be history.
  8. #138
    Romania
    Fixed it the old fashioned way: uninstall and install again.
    I still find it a little tricky to configure. Will this be easier to do in a future release?
  9. #139
    Mar 2004
    Munich, Germany
    Suggestions?
  10. #140
    Romania
    Suggestions?
    Sorry, I meant in terms of configuring it to do stuff like toggling forward/backwards in a song (so far this is the only thing missing), not configuring the actual applications, which is pretty easy once you get the hang of it.
    Among many things, I like the fact that when you press next song for example, for a couple of seconds MWI remembers the previous position, so if you want to switch to another song you can easily do that by pressing it again. (sorry, couldn't explain myself better...English is not my native language)
    How do you get ridd of the voice? I've set all things in the configure menu regarding voice to false, but the voice is still there? How can I close the dictionary? I didn't find any use for those letters yet...(in MWI that is... ) I'd find it more usefull if it were only a task switching operation.
    Also, I noticed that if you set it in configuration so that MWI toggles the volume, when toggling through the applications in MWI (so not through their options; for example: Frodo player-media player-roadrunner....) the volume aslo changes. When entering the options for an aplication this problem disapears.
    Same thing happens when in dictionary of switching applications.
    I've used this app everyday for a few days now, and it's ABSOLUTLY FANTASTIC!!! I like it so much I use it on the home pc as well!
    Zorro, you're a genius!
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 6
    Last Post: 03-15-2005, 01:07 PM
  5. High Input and Low input
    By got2liv4him in forum Car Audio
    Last Post: 02-10-2005, 11:38 AM
