Page 4 of 25 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 246
Thread: Input tool using MouseWheel
  1. #31
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    It prints whatever you configure (see <Letters> in the config).
    So did I but then there's no valueable mouse command on the tilt buttons.
    Skinning to go... VisualDesigner2!
  2. #32
    Newbie SpitFire_Pt's Avatar
    Nov 2004
    Portugal
    Looks like a great APP.
    the only problem is that the download link IS NOT WORKING
    thx
    SpitFire_Pt, Burning U Out!
  3. #33
    Mar 2004
    Munich, Germany
  4. #34
    Newbie mportobello's Avatar
    Jan 2004
    Calgary, Canada
    Very innovative. Great job!
    1997 Toyota Celica
  5. #35
    Mar 2004
    Munich, Germany
    Thank you. As soon as I get the Powermate SDK, I'll try to adapt it.
  6. #36
    Mar 2004
    Munich, Germany
    It took me a while to get the SDK from Griffin Technology but now it's done.
    MWI now supports the PowerMate as announced. Download the new binaries and do the following:
    Add these tags to your MouseWheelInput.Config.xml:
    <UsePowerMate>true</UsePowerMate>
    <UseMouseHook>false</UseMouseHook>
    <SlowDown>4</SlowDown>
    <SwitchToDictionaryTime>2000</SwitchToDictionaryTime>
    Set SlowDown to decelerate the PowerMate (a value of 4 or 5 has been proofen useful) because it acts a bit faster than the mouse wheel. Since the PowerMate has no extra buttons, set SwitchToDictionary to any value you like (in milliseconds) to focus the dictionary list automticaly after the defined idle time. This setting also switches back after the timer has elapsed a second time.
    The new ZIP contains PhoneCtl.Config.exe, which is able to handle the MouseWheelInput.Config.xml as well. This is a more conventient way to change your settings.
    Beware! If the second tag in your MouseWheelInput.Config.xml is not
    <MouseWheelInput...> (old version), delete the configuration file before you start MWI.
    If you'd like to use the PowerMate in your own application, drop me a mail.
  7. #37
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Great Job. Now I'm sad cause I donīt have a powermate
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  8. #38
    Mar 2004
    Munich, Germany
    guess, you're better with your customized mouse wheel
  9. #39
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i'm trying to run the program but I get this error, any ideas?
    肚子笑痛了
    S60 Install
  10. #40
    Mar 2004
    Munich, Germany
    - Check .NET Installation
    - Install .NET Framework 1.1 Service Pack 1
    - Don't run it from a Network drive
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 6
    Last Post: 03-15-2005, 01:07 PM
  5. High Input and Low input
    By got2liv4him in forum Car Audio
    Last Post: 02-10-2005, 11:38 AM
