Page 5 of 25 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 246
Thread: Input tool using MouseWheel
  1. #41
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    hrm, quite strange. i'll try reinstalling .NET again. I am not running it from a network drive so I know that is not it.
    肚子笑痛了
    S60 Install
  2. #42
    May 2003
    Miami, FL
    Yes, I am verified running .NET SP1, not running it from a network drive. No luck.
    肚子笑痛了
    S60 Install
  3. #43
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Try the Service Pack first (yes, there's one)
    If you have PhoCo running, MWI is supposed to run either.
    Skinning to go... VisualDesigner2!
  4. #44
    May 2003
    Miami, FL
    No I dont have phoco, i'll try the service pack again. Even though that is just what I tried.
    肚子笑痛了
    S60 Install
  5. #45
    Mar 2004
    Munich, Germany
    Oops... my fault. Try to rename WMIBridge.dll to MWIBridge.dll. If that doesn't help, download the ZIP once again.
  6. #46
    May 2003
    Miami, FL
    no dice, diffrent error though
    肚子笑痛了
    S60 Install
  7. #47
    Mar 2004
    Munich, Germany
    Please download the Cab once again... it has to be the bad named DLL.
    Are you using PowerMate or do you just try to use the Wheel Mouse?
  8. #48
    May 2003
    Miami, FL
    I want to end up using it with the powermate, but for right now I was just going for wheel mouse
    肚子笑痛了
    S60 Install
  9. #49
    May 2003
    Miami, FL
    ok, so now i've uninstalled .NET framework, reinstalled .NET framework, downloaded the package again and this is what I get
    肚子笑痛了
    S60 Install
  10. #50
    Mar 2004
    Munich, Germany
    Yap. Please copy this config file into the directory (and remove the .txt):
    Attached Files Attached Files
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 6
    Last Post: 03-15-2005, 01:07 PM
  5. High Input and Low input
    By got2liv4him in forum Car Audio
    Last Post: 02-10-2005, 11:38 AM
