Page 7 of 25 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 246
Thread: Input tool using MouseWheel
  1. #61
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Would you mind to download this tool: http://www.sysinternals.com/Utilities/DebugView.html
    let it run before you start the test-app and send me the logfile afterwards?
    Skinning to go... VisualDesigner2!
  2. #62
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    ok, here you go
    Attached Files Attached Files
    肚子笑痛了
    S60 Install
  3. #63
    Mar 2004
    Munich, Germany
    Ok, I think I got it now. Use the attached DLL.
    If it still aint working, please send me the logfile again.
  4. #64
    May 2003
    Miami, FL
    no dice, one question though, do I need to change any settings in the powermate control program?
    log attached
    肚子笑痛了
    S60 Install
  5. #65
    Mar 2004
    Munich, Germany
    Upon the logfile I see that the device was found, so it's supposed to be working.
    What's the test-app doing?
    For testing purposes it's better to kill the PowerMate UserInterface. Depending on the settings there, it might happen that MWI isn't getting the inputs.
  6. #66
    May 2003
    Miami, FL
    Ok, so I tried killing the powermate App, no change
    the test program should interact with the powermate right? I should be able to change the brightness and stuff?
    肚子笑痛了
    S60 Install
  7. #67
    Mar 2004
    Munich, Germany
    Yap. Tick the Pulse checkbox for a quick test.
  8. #68
    May 2003
    Miami, FL
    Ok, so I tried the test app again, i've tried starting it with the powermate program enabled, disabled. I have tried disconnecting and reconnecting the powermate while the test app is running. It just appears to do nothing at all
    肚子笑痛了
    S60 Install
  9. #69
    Mar 2004
    Munich, Germany
    Strange. Are you running the test-app from the same location as MWI?
  10. #70
    May 2003
    Miami, FL
    yes
    肚子笑痛了
    S60 Install
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 6
    Last Post: 03-15-2005, 01:07 PM
  5. High Input and Low input
    By got2liv4him in forum Car Audio
    Last Post: 02-10-2005, 11:38 AM
