Page 1 of 25 1234567891011 ... LastLast
Results 1 to 10 of 246
Thread: Input tool using MouseWheel
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Hi Guys,
    just built a nice little tool for entering keystrokes using the mouse wheel only and thought, you might wanna give it a try.
    After you've copied it to your harddrive and you run it, you'll get this picture on the screen:
    As you can see, it shows you a small tootip window, displaying the currently selected, the previous and the next character in the queue. To select a character, simply turn the mouse wheel. When you reach the character you need, click the mouse wheel button and it'll be send to the current control (which is supposed to be a textbox). Do that until you've completed your input.
    Further you see the window is split in four regions, whereas 3 of them have a special meaning:
    - BS sends a Backspace whenever you click it (with the left mouse button)
    - CR sends a Carriage Return
    - Func switches between normal characters, numbers and special characters
    Once you stop turning the mouse wheel, this window will hide itself. To bring it back, simply hold down the wheel button until it pops up again (this timings are configurable as well).
    What characters you see there browsing through, is defined within the according section in the configuration file. Feel free to edit and change this according to your needs.
    Also in the configuration file you can apply colors, position and font settings. I'd say, the configuration is self explaining (for those who know me: yes, it is XML - you can use PhoneCtlConfig.exe to change it)
    Needles to say that it's .NET and therefore it needs .NET Framework to run it.
    If you try it, please be aware that it's just capturing mouse input. Since it doesn't consume it completely, it may happen that the application in foreground reacts on the wheel command as well.
    You can download it here: MouseWheelInput.zip
    Skinning to go... VisualDesigner2!
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Interesting idea...
    Mar 2004
    Munich, Germany
    Yeah... but useless for you ... .NET... you know
    Jan 2004
    Jersey/NY
    whoah, sweet prog.. haven't had a change to use yet, but I'm sure I'll need it, especially since the "i-drive" type of knob I have acts as a scroll wheel.
    Thanks!
    Mar 2005
    Czech republic
    Quote Originally Posted by zorro
    RIGHT! Agrrrrr....
    Well, you still have got my compliment for invention and the end result.
    Now get back to chair and code it again from scratch in Delphi 8 or something.
    Bloddy coders...
    Mar 2004
    Munich, Germany
    A small improvement: If the window is open and you hold down the mouse wheel button it'll switch function mode (normal / numbers / spec. char) without the need to move the mouse and click the upper right corner.
    Mar 2004
    Munich, Germany
    Quote Originally Posted by LagunaICE
    RIGHT! Agrrrrr....
    Bloddy coders...
    I could do that... but I love doing .NET so much.
    BTW: I recognized that there is a slight performance problem using .NET with on a Via Epia Mxxxxx. So I replaced my M10000 with an old notebook (Pentium III 1Ghz) and all performane issues were blown away.
    Beside, there are so many other benefits using a notebook. e.g. no more reset on starting the engine, you can use it elsewhere than only in your car.
    Pity I don't have a docking station for it... it'll be more comfy removing it.
    Mar 2004
    Munich, Germany
    Talking Field testing
    Works great
    Mar 2004
    Munich, Germany
    Some comment on this?
    Raw Wave justintime's Avatar
    Apr 2005
    I personally dont have any use for this tool, but I tried it and I like it. Well done.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. Phone style text input applet (with Source code!)
    By Dominik in forum Software & Software Development
    Last Post: 05-19-2008, 06:58 PM
  2. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 06:09 AM
  4. Replies: 6
    Last Post: 03-15-2005, 01:07 PM
  5. High Input and Low input
    By got2liv4him in forum Car Audio
    Last Post: 02-10-2005, 11:38 AM
