Page 16 of 24 FirstFirst ... 6789101112131415161718192021222324 LastLast
Results 151 to 160 of 234
Thread: StevieG's Access Control Software
  1. #151
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I've had a look at the video thing. Trouble is the only VB OCX I can find that allows this insists on popping up a settings box. Which kind of defeats the object. Maybe an autoit can be run to automatically clear it.
    Unfortuantely haven't had time to add to this.
  2. #152
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Not a major problem, i am looking at a car based DVR anyway which has GPS speed overlay etc. This will be based on the VideoCap Live ActiveX Control, the only thing is the OCX licence is quite expensive for a one off !
    What do you reckon on the 1 attempt fail and then record idea ? Is this easy to implemement ?
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  3. #153
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Tissy
    Very easy, would be something that could be added to the ini, so people could choose whether they want it immediate or after a particular number of attempts.
  4. #154
    Sep 2005
    Would you be able to look into this or point me in the right direction, i have the source code. Unfortuanatly its not in english, so a little difficult to translate.
    Many thanks,
    Steve
  5. #155
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It's only the class module that is commented in non english.
    I have just made the changes to the code that I have. It now reads a number from the ini and will only record after that amount of failures.
    ie 0 means it will record straight away 1 - (infinity) after that amount of failures.
  6. #156
    Sep 2005
    Cool !! What part of the code was changed and can you send / post the changes so i can do the same to my source code.
    Does the version you have also have where you can set the directory in the ini file of where to save the recordings.
    Can you either post the latest version (and source) or send it to me at steven@wrx-carpc.co.uk
    Many thanks for your efforts,
    Steve
  7. #157
    Sep 2005
    Enforcer - I've now added beeps to the button presses which sounds very nice indeed. If an incorrect code is enetered it then warns verbally "system recording". Can you send me the code additions to what you have done, then i think i have all that i need for a great app.
    I'm also thinking of adding 2 buttons which appear only once a correct code is entered. These will give the choices of exiting to windows or to load the CarPC front end, such as Road Runner. If you start the CarPC and only want windows then you will have to wait for the front end to load, only to then exit. This will add flexibility.
    PM me your email address and i'll send you the .exe and sound files i have so far.
    Regards,
    Steve
  8. #158
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    there are email contacts on my website use one of those.
    cheers
    buttons seem an interesting idea.
  9. #159
    Sep 2005
    Enforcer - Sent you the email, did you get it OK? What do you think ?
    Steve
  10. #160
    Sep 2005
    bump
  1. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  2. Software to control A/C - Heater ?
    By henriktha in forum General MP3Car Discussion
    Last Post: 10-27-2004, 01:55 AM
  3. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  4. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
  5. Need software for X10 remote
    By Dimitris76 in forum Software & Software Development
    Last Post: 12-26-2000, 05:11 AM
