Ah that might be because i have made my own skin file. You will have to change the Skin from "Simplistique" back to "Centrafuse" in the ini file. That should work then.
What i am really after is the code you have altered so that you can change the amount of passcode attempts before it starts recording. I presume it is only a couple of lines of code. Can you post them here and in what module they go in.
I will look into the skin selecting issue, so if no skin is entered in the ini, it will default to another one.
Many thanks,
Steve
LinkBack URL
About LinkBacks
