Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 161 to 170 of 176
Thread: iGMod Beta 1 release
  1. #161
    Aug 2004
    can you set up the http://sterlingv.com/users/purdoom/alpha8.rar dl I can't seem to have any luck dling from your link
  2. #162
    Raw Wave tj!2k4's Avatar
    Oct 2004
    i haven't been able to road-test it yet, but so far i'm seeing the following bugs:
    - speed box isn't magnified
    - buttons have black edges where they should be transparent
    - menus appear laggy
    - when entering test using osk, sometimes the first button press doesn't enter the character, especially if it is the first time you're pressing a button on a "new" menu
  3. #163
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    There's not PNG's? Oh well, I still like the progress on it.
    2002 Grand Am progress :
    [] - 80%
    ...complete setup, but still need to make the install cleaner
  4. #164
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Ok ill take a look at that
    That should be an easy fix.
    Howso? The new beta keeps the menu on the screen with the button down while its doing its behind the scenes stuff, so you have a good indication of when the command you clicked is finished. Does the actual execution feel any slower then it used too?
    Ill take a look at that as well.
    -the custom panel speed alert button doesnt work
    What its supposed to do is enable or disable auto speed alert. Perhaps ill make it give some sort of indication of what the new state of the speed alert is.
    -and the next turn > view objective and cancel buttons work but dont show the Route list at the top
    The screenshot showed a turn in progress, not the actuall turn. That would be a nice feature however; to show what turn is being previewed. Not sure how I would set that up though. Im sure I could think of a way.
    -can you set up the http://sterlingv.com/users/purdoom/alpha8.rar dl
    Done
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  5. #165
    Oct 2004
    i'll take a little video when i get home, it's hard for me to describe the laggy menus..
  6. #166
    Raw Wave
    Jun 2002
    Virginia
    I'm curious to see what David decides to do about his use of Teletype as the "built-in" GPS software for CF
    David posted yesterday that he will not be using Teletype because the SDK isn't any good.
  7. #167
    Apr 2005
    how do i embed igmod into centrafuse? i would like to replace the "radio" button with a "GPS" button. thanks in advance!!
    Dave
  8. #168
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by beeman
    Dave
    Edit buttonactions.xml. In there, replace GLOBAL 2's action with APP1.
    Edit external.xml. Under <APP1>, change the path to the appropriate path for igmod, set windowname too igm, and displayname to GPS. Also set enableheader to false.
  9. #169
    Apr 2005
    thanks! however, i am having trouble with igmod's window size...is it adjustable? i can't get it to dock in the centrafuse window.
    Dave
  10. #170
    Jun 2005
    Anoka County, MN
    Dave
    In the file external.xml, make sure it says:
    Code:
    <WINDOWNAME>igm</WINDOWNAME>
  1. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  4. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
