Can't wait to get back from vacation and download and install this program...!
I removed some code preventing the menu from clicking at all in the beta 2 and gave it to someone, and that works but apparently he cant see the skinned menu. So I am working with him to get it resolved.Originally Posted by Wiredwrx
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
I think I got the no menu issue resolved, it seems my program was picking up on some child window with no title and now it ignores it. And redoing all the buttons to support external skins instantly solves the "menubutton does nothing" problem.
Not for another couple days.Originally Posted by abojad
hey purdoom awesome app
im runnin an old 1 ghz duron compaq 700a presario...only 256 ram. when using CF 1.4 with your app it looks and runs quite well for navigation, however the adress input process is horridly slow. is it because windows relies on my s3 twister k laptop video card to render the magnification? i run on a 7 inch indash at the 800x600 stretched resolution. after i input street name and house number the list i get for the streets is unbearably slow to scroll through. also is it normal to see the original iguidance menus before your overlay appears?...haha i think my laptop is THAT slow.
note: i would request if anything if you could give the option of unputing city first then street, house #, etc so that users would avoid the hassle of scrolling through a list of streets in different cities. thank you purdoom your app rocks!
I've been playing with iGMod, and how does it do the magnification? Does it hide itself, and capture the screen?
It uses a timer that runs every half a second to capture the screen using some code I got from "thescarms" (http://www.thescarms.com/vbasic/capture.asp) which apparently is cappable of capturing the contents of objects when other things are on top of it. Edit: For people reading now, it turns out there is more too it than this. PM me if you really want this info.Originally Posted by 0l33l
The streets being slow is a big problem... rather than running the object native what the program is doing now is sending your screenpresses onto the control as mouseclick events and then recapturing the image zoomed up. Once I figure out a faster way to do that ill implement it.
It is normal to see the old menus for a second before the new menu appears. Im also considering solutions to that, my idea is to freeze the screen image for a second when the program expects to see a menu then release the screen when the new rendered menu is ontop, which will make it seem like there is no old ig menu between hitting a command and the menu appearing. Im already using a system like this to hide the effects of the weird resizing when the program starts in beta 2.
the memory reader dll is done, also if you'd like to use INIAccess, this is incorporated into the DLL. This DLL is not specifically for Iguidance but can be used with any application.
the following link is a directory listing containing 3 zip files
1 is the DLL source
1 is the DLL and INI file
and 1 is an example of using the DLL file in VB.NET (commented are the other functions of the dll)
http://www.zebralot.com/mp3car/Memory%20Reader/
The INI file is not complete....its a start....each person must find the memory values for speed destination....etc themselves. (maybe one day, I or someone else will make a tool that will pull these values for you......for now I'm not sure how to accomplish this)
PC Components:
My work log
Do you have reasonable confidence where speed is located? If so I could make a truetype font for the speed rather than the pixelated zooming.
