Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 71 to 80 of 176
Thread: iGMod Beta 1 release
  1. #71
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    not really, after an unknown turn of events the memory value jumped 4 bytes after several months on my machine. On LostReception's 2k machine the value is a few hundred bytes away. However, there are clues as to where it is located. On machines configured the same way, the value is always in the same location. Obviously settings and system variables are what change its location, the question is which ones and how do we anticipate this?
    At one time I located a value that signified the port my GPS was connected to.
    I've also found a value that become either 254, or 255 everytime the Speed is recalculated....and this value always seems to be exactly 3 bytes below the speed address
    PC Components:
    My work log
  2. #72
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Ow, converting to external skins is taking some effort.
    Is a format similar to this acceptable for you skinners?
    Code:
    ;Menu Compas Image
    BUTTONLAYER_BUTTON
      IMAGE "\images\menuup.bmp" "\images\menudown.bmp"
      IMAGENIGHT "\images\menuup.bmp" "\images\menudown.bmp"
      ANCHOR BL
      XMOD 3
      YMOD 48
      ACTION
        GOMENU
        KEYS X
      SPECIALNAME GPSInfoHolder
    END_BUTTON
    ;Zoom -
    BUTTONLAYER_BUTTON
      IMAGE "\images\zoom-up.bmp" "\images\zoom-down.bmp"
      ANCHOR B
      XMOD -85
      YMOD 48
      ACTION
        KEYS D
    END_BUTTON
    ;Zoom +
    BUTTONLAYER_BUTTON
      IMAGE "\images\zoom+up.bmp" "\images\zoom+down.bmp"
      ANCHOR B
      XMOD 85
      YMOD 48
      ACTION
        KEYS U
    END_BUTTON
    ;View
    BUTTONLAYER_BUTTON
      IMAGE "\images\viewup.bmp" "\images\viewdown.bmp"
      ANCHOR TR
      XMOD 150
      YMOD 4
      ACTION
        KEYS 3
    END_BUTTON
    Ive made an elaborite readme on how to make skins as well.
    Edit: Detour support was broken this whole time and nobody noticed? Wow.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  3. #73
    Raw Wave lostreception's Avatar
    NY
    in 2k i searched for the current value of speed and found this value AE1458 its the speed directly off of the gps stream the program would just need to round up or down based on the output someone on xp check for this value too
    its got to exist on the xp machines as well use trainer and search for float and you should find it
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  4. #74
    Jun 2005
    Anoka County, MN
    I have the next beta nearly ready, but I need some testers for it before I accidently put out a buggy version. PM me if you could help.
    So far:
    - RR support
    - Frodoplayer support
    - Smother menu transitions
    - Less painfull to watch loading screen
    - External skin file for modification
    - Screenpress sounds (ripped from centrafuse)
  5. #75
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by PURDooM
    So far:
    - RR support
    Do what I do and just release it. The people here are beta testers
  6. #76
    Nov 2004
    Quote Originally Posted by 0l33l
    Agreed. Users of this board live to beta test ;-)
    André
  7. #77
    Aug 2004
    I have a feature request not sure if anyone else does this or not I like the mute on the main screen but if you could put a quick link off of the main menu to mute that would be great
  8. #78
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by lagunatl2k
    Ill try to edit the skin appropriatly.
    Alright heres the alpha:
    http://igmod.iamjeremy.com/alpha4.rar
    Problems im aware of right now: Press detour while no route is set will cause the skinned interface to die and you will be left with plain old iGuidance.
    Some people have some really weird effects where the buttons flicker and the menu doesnt do anything, still working on this.
    Im going to make a centrafuse 1.4 skin soon as well, unless somebody else wants too
  9. #79
    Aug 2004
    I tried the link Its not working for some reason
  10. #80
    Jun 2005
    Anoka County, MN
    Try it now; ive been uploading some quick changes to the readme and skin.ini and that probably caused an interuption in service.
  1. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  4. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
