Page 10 of 63 FirstFirst 123456789101112131415161718192060 ... LastLast
Results 91 to 100 of 626
Thread: iGmod Beta 2 release
  1. #91
    Mar 2004
    Hey man i have noticed that there has been some problems with gmod working with a couple other people including myself. "menu button doesnt work" Man this program looks supa tight and i really wish i could use it ver (2.1x)i thnk it is
    thanks
  2. #92
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Spec-pc
    thanks
    Nah, that version is weak compared to what I have been working on.
    Following RPM_V4's example... I present iGmod Reloaded preview! This is so those who sent me donations can see what their donations have been working for.
    http://sterlingv.com/users/purdoom/i...dedpreview.rar
    Working:
    Entering an address
    Embedding (set window search string to _iGmod_ in your front end)
    Zoomed speed (not distance yet)
    New skin style
    Custom buttons (excluding next turn button)
    New CF nag screen (which you can of course disable by setting the value in runner.ini for the nag screen to false)
    Major features you would expect but arent in the preview:
    Practical use in stand alone mode (it doesnt show up in the taskbar yet)
    Zoomed up skinned window for the search results/favorites/recent boxes
    DONT press the options button, you end up with a menu you cant close on the screen. Forgot to rip that out of the skin in the preview.
    Things that just plain arent in there yet
    GPS info embedding
    Next turn guidance display like igmod 1 had
    Preview next turn
    POI support
    Options menu
    Improvements to the exsisting features expected:
    Customizable loading screen
    Better directory/file layout of release
    Faster load times (It takes about a minute and a half to load on a painfully slow 350mhz computer while the computer is decoding mp3s)
    European support (I have iguidance europe here, I just havent programmed the skin to use it yet)
    At this rate... ill have everything well done in a week or 2 perhaps? Patience and attention to detail will make a better product.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  3. #93
    Raw Wave justintime's Avatar
    Apr 2005
    Thanks for sharing.
    Few suggestions based on what I see:
    1) When entering Guidance mode, can you temporarily remove the Zoombox, Zoom plus, ZOom minux, and 3d buttons? Basically, can you remove everything on the lower right corner so it does not get on the way? You really can't performa any of these actions when in guidance mode anyways (I think...!)
    2) When moving the map around, the 'Red X' close button appears on the lower right. Where you intending on puttin a bigger version of the red button? Something weird happens in that area after dragging the map around...
    3)Seems like there is a lag (1/2 second) between the time I click a button, and the time I hear a 'click' and it takes effect. It does get on your nerves a little. Any hope for more snappiness?
    Overall, this is looking like a miracle app! Great job man!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #94
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by justintime
    Thanks for sharing.
    1. Yea, I had something similar going on in beta 2. It will be there.
    2. Same feature will make that happen.
    3. Actucally I introduced a delay of about half a second because immediate clicks made it so you couldn't see if the down image was ever displaying (debugging). Ill rip that out and update that link for ya.
    Edit: Updated.
  5. #95
    Apr 2005
    Queens, New York
    When entering an address it takes an awfully long time to respond! It take way to long to load the data base. I think you should put that last screen you have at the end where it says " Enter City" / Enter State" / // put that at the beginning so maybe it will speed things up!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #96
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by Cheekz185
    I noticed that when I ran it in my car a few hours ago. Whats happening is it is pressing menu->destination->address->by street then waiting for the street list to come up before it tries processing any more events. Ill try to make a workaround that allows you to enter text before the behind the scenes stuff is done.
  7. #97
    Apr 2005
    Queens, New York
    is it any way possible to make it user configurable to choose what you want the address to ask first?
    personally I would like to Be able to Choose STATE ---> Town(CITY) ---> Street ---> House Number
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  8. #98
    Jun 2005
    Anoka County, MN
    Right now its somewhat difficult (there is some crazy logic going on in the skin file to acomplish the input the way it is) but I plan on releasing a skin configuration tool somewhat soon to automate that for you.
    However until I make that release, if you head into the skin file and look for the block of text like this:
    Code:
        ACTION
    	SHOW_MENU "SetDestination2"
            HIDE_MENU "Main Menu V2"
      END_BUTTON
    And change "SetDestination2" to "SetDestination2State" then the first menu that will be pulled up when you press address is the OSK for state. OR... "SetDestinationConferm" will give you the master screen with all 4 entries.
    Also cheekz... I will have the program onload events working soon so you can set your GPS to com 10 or whatever it was like you could before.
  9. #99
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Hey DooM, looks good m8! keep up the nice work. Although it did take about 30sec to load on a 3.4 P4 (doesn't really matter to me). This is the best thing i've seen for iG yet!! donation on the way soon
  10. #100
    Aug 2005
    Jersey
    nice, I'm glad to see the improvments, I haven't yet tested them because my carcomputer system is going thru a major overhaul but it should be up and running again properly by next week. I actually am running a PIII 600 w/ 384 Ram w/ road runner and igmod 2 currently, and its pretty good. I originally ran win2k pro sp4 on it and the gfx in iguidance/igmod were choppy as hell, but after upgrading it to XP pro it works awesome. I guess this info is irrelevant so I'll just shut up until I either try to preview or the release (depending on when I have the ability to update the software on my carputer again)
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
