Page 13 of 63 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 626
Thread: iGmod Beta 2 release
  1. #121
    Aug 2005
    Jersey
    Quote Originally Posted by skippy76
    Hey PURDoom: Keep up the good work. ONe constructive critasism is that we seem to be loosing a lot fo the map view. I would like if possible to have a whole screen map view with maybe an info pane at the top. If we select the info pane then a menu could appear taking up half of the screen, similar to RoadRunner's support of MapPoint. After a configured period of time the memnu then dissapears.
    Andrew
    don't forget... what ur seeing is also 800x480 in CF. If you are using road runner, there won't be all the centrafuge wraparound and there will be alot more map area...
  2. #122
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    1. you can press centrafuse's title bar to go into full screen
    2. there is/will be an option in the custom menu to remove the gui enhancements
    Screenshot at 800x480:
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  3. #123
    Apr 2005
    Queens, New York
    I think that iGmod needs its own forum under Support Software! Get it out of "Other Cool Stuff" and make PurDoom the forum leader!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  4. #124
    Aug 2005
    Jersey
    Quote Originally Posted by Cheekz185
    I'll second that!
  5. #125
    Jun 2005
    Anoka County, MN
    If/when that happens i have plans to make all kinds of stickys. The how to code skins tutorial is going to be pretty extensive
  6. #126
    May 2005
    hi PurDoom this is greate.. can you please how to use it i ran the igmod.exe file and it started iguidance but how do i change the car icons that are included in the ziped file i downloaded. Also how do i integrate it with frodoplayer.
    thanks
  7. #127
    Jun 2002
    Virginia
    Hi PURDooM,
    I downloaded and installed the new preview. It's looking good!
    I do want to let you know that whenever I hit the POI icon in the main menu, the program freezes. I know this is just a preview and maybe you're already aware of this, but I thought I would point it out just in case you're not.
    Keep up the good work!
    Kevin
  8. #128
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by kbreeden
    Hi PURDooM,
    Kevin
    Yea, whats actually happening is its saying "this action is broken" but you cant click the ok box because the menu is always on top . Ill fix that right now for the next release.
    I haven't thrown in the frodoplayer integration yet. As far as the car icons run the patcher in the patcher folder and it will make you have the big icons. I tried adding the eclipse icon for the car icon but it just didn't look right.
  9. #129
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by PURDooM
    Don't know why, but my install is running GREAT! Load time is a little long but everything seems to work that I've tried. I would like to do some skinning so that it matches my RR skin though. I'd also like to see the option of selecting different ways of locating an address/poi (eg: city first, street first, by distance, by type, etc.) like the native options in IG. (BTW: Where's the wav file the makes the keypress sound? I'd like to change it.) Thanx!!
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  10. #130
    Jun 2002
    Virginia
    My install is also running very well with the latest IGMod preview embedded in CF. It seems very stable. I have not pushed every button, but so far the only issue I've seen is that it locks when I hit the POI button.
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 11:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 04:08 PM
