Page 20 of 63 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 626
Thread: iGmod Beta 2 release
  1. #191
    May 2005
    Vienna, VA
    Yeah man. There's about 20K cities in the US alone. So they've managed to add ONE FREAKING POI per city since last time. Whoop-pee-dooo.
  2. #192
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by PURDooM
    You can get the latest exe at: http:/igmod.iamjeremy.com/iGmod.exe
    With this version I get NO buttons! Only the map.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  3. #193
    Aug 2005
    Jersey
    lol I had that problem... check your runner.ini
  4. #194
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    yea, im making changes to what is nessesary in the skin.ini and runner.ini with each preview. Make sure you have all the lines and arent just updating your exe.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  5. #195
    Aug 2005
    Jersey
    mmm the new exe is nice.... but I"m having one issue -
    in my car, when I load up IG in CF (P3, 600) no dialog box that has to list addresses works *at all* it just comes up with a screen shot of whatever is behind the box. I can't get recent, can't get favorites, can't get anything. I dunno why.
    if, however, I load it up in RR, it works perfectly.
  6. #196
    Sep 2003
    Thousand Oak, Ca
    This is great! Donation has been sent.
    A few issues. Sorry if these are already listed, I scanned this thread but it’s getting pretty long.
    I can’t find favorites.
    When I try to select an address from the list it jumps to the top of the list for a second then jumps back to where it came from.
    My hardware keyboard doesn’t seem to work with the osk.
    When I fist loaded Imod I had IG 2.01 then upgraded IG to 2.02 and still had the same problems.
    I’ve been doing some skinning, is there a way to add more buttons to the main screen? I would like to have a mute and a north/heading button. Can the speed magnify window be moved?
    Are the current street (bottom line) and next turn street name (top line) able to be magnified?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    you can set up ur front end to open two instances of igzoom to zoom in on those bars. There is no current way to do it thru iguidance.
  8. #198
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by mskrzat
    No problem
    I couldn't fit favorites onto one of those CF themed buttons, so I named it custom instead. In the preview the ability to add to favorites is currently broken.
    Thats because right now I have no idea how to pull what is in that box, all that I can remember is the street name you are typing in. For now at least.
    Its on the todo list
    2.1.2? Yea there isn't any real difference between NA versions of iguidance yet anyway.
    Press custom and they are right there for ya. Are you using the latest version listed in my sig line?
    But yes you can modify the skin, the main buttons are somewhere near the top. Ill help you with this later, gotta go to school.
    Ive been getting alot of requests for this. I think ill add it as a toggle that is disabled by default soon.
  9. #199
    Mar 2004
    Los Angeles Area
    So preview3 WILL work with my 2.1.1NA? Here's a quote from your announcement:
    What doesn't work:
    -2.0NA (i cant execute it to see if it looks right) / 2.1.1NA (I apparently have the wrong version)
  10. #200
    Jun 2005
    Anoka County, MN
    Quote Originally Posted by wysocki
    The annoucement says 2.1.1 wont work with the included patcher
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 10:17 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    By veetid in forum Centrafuse
    Last Post: 08-02-2005, 10:20 AM
  3. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 03:13 AM
  4. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 04:03 AM
  5. RELEASE - FreeDrive 0.33 beta (D3 Frontend)
    Last Post: 02-18-2005, 03:08 PM
